What current-limit accuracy should we allow around 256 mA on the Tic T825? For 12 V operation, what external VIN capacitance or transient suppression do you recommend, and under what conditions?
We generally expect the current limit to be accurate to a few tens of mA (and you can see this post for details about the allowable settings on the Tic T825). Ultimately, how well it works will depend on various factors of your system. For example, if you are driving the motor from a voltage that is many times higher than it is rated for, the current might ramp up so quickly that it is hard for the driver to maintain reliably.
As far as capacitance on VIN, there is some built into the board already, and whether or not you need additional capacitance (and how much) depends on your particular setup. Ideally, if you have problems and need to add capacitance you would use an oscilloscope to monitor the behavior as you do to find an appropriate amount.
