Pololu A89301 Configuration Utility
I’m trying to run the Pololu A89301 Configuration Utility
(https://www.pololu.com/file/0J2191/pololu-a89301-windows-1.0.1.zip)
I’ve downloaded the zip, expanded it and run the setup.exe.
It seems to run to completion, but I don’t know where the actual program is now.
I’m using Windows 11 and I tried searching for Pololu and 89301 but nothing shows up.
There’s nothing new on my desktop either.
A little help please…
We had another user report the same problem recently (although we have not been able to reproduce the problem ourselves). Could you try following the suggestions in that thread and if necessary follow the instructions in my last post to post screenshots of your Event Viewer here?
I just reread your post and realized I might have mis-read it the first time. If it is just a problem of finding the executable (and not related to the other thread I linked to) you should be able to find it by searching for “A89301” or “A89301 Configuration Utility”. If that does not work, the default location for the executable should be C:\Program Files (x86)\Pololu\A89301
Thnaks. I did find it eventually :slight_smile:
