I recently encountered a problem with my jrk 21v3. the output voltage is not enough. I checked it with multimeter it is around 0.2 V. It was working fine before by outputting 5 V. The motor barely moves.
Could you please let us know a bit more about your setup? How are you supplying power to your system? Could you measure its output to be sure it is still good? What are you commanding the motor to do when you check the voltage? Could you please post your jrk settings file?
How are you supplying power to your system? power supply.
Could you measure its output to be sure it is still good? It seems that it just got locked on 0.2 V. It was working just fine earlier. We bought encoder and introduce sin waves to system and motor was doing sin waves in high accuracy, but now, it can’t even provide constant 5 V…
What are you commanding the motor to do when you check the voltage? Pushing the “run motor” bottom. the feedback is off…
Could you please post your jrk settings file? Ok. i did.
System is supplied by power supply with 5V. the same configuration that was working before. Max current input is set at 800 MA which is motor’s Stall current @ 4.5V.
I suspect something shortened out on a circuit, but i don’t know which part burnt out.
It was working properly for several months. If we could find the possible cause of this issue we can probably avoid it in future.
From the settings file, it looks like the Current Max setting on the Motor tab was set extremely low at 0.037A. The jrk’s current limiting feature adjusts the effective voltage supplied at the motor outputs. So, if this current is a low value, the output voltage will also be low. Could you try increasing the Current Max value to see if that works?
If that doesn’t work, you should try just resetting your settings to factory defaults and checking to see if you can get a motor moving (without feedback) from the jrk configuration utility. While the board might be damaged, it seems like you might also just have some weird settings. To reset the settings, select the “Reset to default settings…” option from the File menu.
I did reset the jrk settings. There was no change so i was convinced that Jrk was damaged. We got new Jrks, but I am experiencing the same issue.
The motor is rotating very slowly, and jrk’s red LED goes on and off. start/stop bottoms on “jrk configuration utility” also goes on and off very quickly.
More current is also needed from power supply. I am assuming the motor is half burnt out?
Motor seems fine when i directly connect it to power supply…
If you disconnect the motor from the jrk and just look at the jrk’s motor outputs with a multimeter when commanding it to move at full speed from the configuration utility, do you see the full supply voltage?
It could be a problem with your motor, but the more likely culprit is your power supply. Can you try with a more powerful (and, ideally, higher-voltage) supply and see if the problem goes away. If the motor runs fine when connected directly to the power supply, then the motor is probably okay, but this is not enough to conclude that the power supply is appropriate for that motor.
