I want to use the TB6612 (your item 713) in paralleled use. How do I do this?
Just parallel the connections PWMA and PWMB, AIN1 and AIN2, BIN1 and BIN2, AO1 and BO1, AO2 and BO2 ?
Any suggestion and help is apreciated.
Thancs,
Joachim
Thancs,
Joachim
It sounds like you are on the right path, but two of the connections you proposed are not correct. AIN1 should be connected with BIN1, and AIN2 should be connected with BIN2. The rest of your proposed connections look correct.
Grant
Hi Grand,
thank you very much for your reply. And thank you for the update of the wiring.
greetings,
Joachim
A post was split to a new topic: Parallel two TB6612FNG dual motor driver Carriers
