I am missing the Inductance (L) of the motor which is not calculated but always given.
Also I understood the max efficiency data and performance graphs were not available for motors that doesn’t have a gearbox, can someone confirm it?
We do not have max efficiency data or performance graphs for the motor without the gearbox (item #4840). Please keep in mind that the motor comes with a non-removable pinion gear installed that works with all of our 25D mm gearmotor gearboxes and is primarily intended to function as a replacement motor and encoder for our gearmotors.
Thank you for your quick answer. I intend to use this motor with a designed mechanism at the output instead of a gearbox but I will stay aware that this was not the original purpose of this product.
