Microgearmotor LP 6V 210:1 Inductance and moment of innertia
Does anyone know the inductance values for the LP 6V 210:1 microgear motor? and what parameters to use to compute the moment of inertia and viscous friction coefficient?
I am aware there is this post, but it’s not the same type of motor parameters another motor
Thanks in advance
Hello, Bruno.
The inductance of our low-power (LP) Micro Metal Gearmotors is about 3.4 mH.
You can estimate moment of inertia and the viscous friction coefficient using the same methods discussed in the post you linked to. The dimensions, specifications, performance curves required are in the Micro Metal Gearmotors datasheet which is available on the product page under the “Resources” tab.
- Patrick
Thanks patrick!
