I’m writing because I didn’t find a clear answer about this subject in the forum.
I found those topic wich are close but do not explain anything.
- Zumo 32u4 usb device not recognized by windows 10
- Wrong driver installed for 32U4; how do I uninstall?
Here is my problem:
I did use the documentation to install the driver and the arduino IDE. Everything was fine and working for a while. Between 2 code uploads, the COM port stopped being recognized.
When I checked on the driver, I have this error, wich is apparently common when it is not installed:
I restarted everything but, since this error appeared, I can’t manage to make it functional again.
Therefore I have 2 questions:
Does a corrupted program could technically breaks the driver?
How can I uninstall the driver? On the documentation, there is no indication on that, only to install it.
Anyway if you could help me on this one, I would be very grateful.
P.S. : I’m not sure about the category. Feel free to drive me where this topic goes if needed.
Thanks,
Mat
