I was wondering if you knew if the ESP32-Devkit-32UE and Pololu’s Micro Maestro Servo Controller (Pololu item #: 1350) were compatible (especially using the existing Maestro Arduino library - GitHub - pololu/maestro-arduino: Pololu Maestro Servo Controller library for Arduino -, or any other known library)? I was able to compile and upload a program to the ESP32 using Arduino IDE, where the code included the Maestro Arduino library (#include <PololuMaestro.h>) and some other functions:
e.g.
#include <SoftwareSerial.h>
SoftwareSerial maestroTicSerial(16, 17);
MicroMaestro maestro(maestroTicSerial, Maestro::noResetPin, 12);
const int wheelTurnPositionChNbr = 0;
maestroTicSerial.begin(9600);
maestro.setSpeed(wheelTurnPositionChNbr, 0);
maestro.setAcceleration(wheelTurnPositionChNbr, 5);
maestro.setTarget(wheelTurnPositionChNbr, wheelTurnPosition);
However, when I go to set the target position, I don’t think I’m seeing any significant change in the max/min voltage on the ESP32’s assigned transmitting output pin (17). Do you know if the Maestro library for Arduino (<PololuMaestro.h>) is compatible with the mentioned ESP32?
The main purpose of the ESP32 was for bluetooth (BLE) connectivity with a PS5 controller, so if they aren’t compatible, I may just send a command from the ESP32 to an Arduino Uno through I2C, and then to the Maestro controller from there, but if I could send directly from ESP32 to Maestro cleanly it would simplify things, so just thought I would ask.
I saw a few other postings that I thought might be related, but wasn’t sure if it was dependent on the specific ESP32 board, other considerations, or just not compatible across the board at this point:
*Can Maestro read 12 bit PWM Output from AS5600?
*Using ESP32CAM Serial to control 18 channel maestro
Just let me know if any other information would be useful.
Thanks,
Josh
