if i did it right there should be the 2 different blocks of code i tried and the new picture.
[code]/*
Optionally writes, then reads, the configuration parameters on the qik 2s9v1.
Please note that the memory used to store these parameters is only rated
for approximately 100,000 erase/write cycles, so you should avoid
repeatedly setting configuration parameters. It is intended that these
parameters will initially be configured as desired and then only changed
occasionally (they are saved in non-volatile memory, which means that
once set, these parameters will retain their values even if the unit is
powered off). For example, you can uncomment the appropriate calls to
setConfigShowResult() below and run this program once to initialize the
parameters. Then, you can load your final program on your Arduino, which
should assume that the parameters have already been set correctly.
Required connections between Arduino and qik 2s9v1:
Arduino qik 2s9v1
5V - VCC
GND - GND
Digital Pin 2 - TX
Digital Pin 3 - RX
Digital Pin 4 - RESET
#include <SoftwareSerial.h>
#include <PololuQik.h>
char* param_names = {
“Device ID”,
“PWM Parameter”,
“Shut Down Motors on Error”,
“Serial Timeout”
PololuQik2s9v1 qik(1, 0, 30);
void setConfigShowResult(uint8_t parameter, uint8_t value)
Serial.print("Setting “);
Serial.print(param_names[parameter]);
Serial.print(” to ");
Serial.print(value);
byte result = qik.setConfigurationParameter(parameter, value);
switch (result)
case 0:
Serial.println(": Command OK");
break;
case 1:
Serial.println(": Bad parameter");
break;
case 2:
Serial.println(": Bad value");
break;
void setup()
Serial.begin(115200);
Serial.println(“qik 2s9v1 dual serial motor controller”);
Serial.println();
qik.init();
// Write configuration parameters
// Uncomment and edit the line for any parameter you want to change.
//setConfigShowResult(QIK_CONFIG_DEVICE_ID, 9);
//setConfigShowResult(QIK_CONFIG_PWM_PARAMETER, 0);
//setConfigShowResult(QIK_CONFIG_SHUT_DOWN_MOTORS_ON_ERROR, 1);
//setConfigShowResult(QIK_CONFIG_SERIAL_TIMEOUT, 0);
Serial.println();
// Read configuration parameters
for (int i = QIK_CONFIG_DEVICE_ID; i <= QIK_CONFIG_SERIAL_TIMEOUT; i++)
Serial.print(param_names[i]);
Serial.print(": ");
Serial.println(qik.getConfigurationParameter(i));
void loop()
// do nothing
[/code]
Required connections between Arduino and qik 2s12v10:
Arduino qik 2s12v10
GND - GND
Digital Pin 2 - TX
Digital Pin 3 - RX
DO NOT connect the 5V output on the Arduino to the 5V output on the qik 2s12v10!
PololuQik2s12v10 qik(1, 0, 30);
void setup()
Serial.println("qik 2s12v10 dual serial motor controller");
qik.init();
Serial.print("Firmware version: ");
Serial.write(qik.getFirmwareVersion());
Serial.println();
void loop()
for (int i = 0; i <= 127; i++)
qik.setM0Speed(i);
if (abs(i) % 64 == 32)
Serial.print("M0 current: ");
Serial.println(qik.getM0CurrentMilliamps());
delay(5);
for (int i = 127; i >= -127; i--)
qik.setM0Speed(i);
delay(5);
for (int i = -127; i <= 0; i++)
qik.setM0Speed(i);
delay(5);
qik.setM1Speed(i);
Serial.print("M1 current: ");
Serial.println(qik.getM1CurrentMilliamps());
delay(5);
qik.setM1Speed(i);
delay(5);
qik.setM1Speed(i);
delay(5);
