Arduino bootloader at 20mhz
Hello, Darth Maker.
With a fresh installation of Arduino 1.0, I was able to load Optiboot on a Baby Orangutan B-328 and then program it via the bootloader using these steps:
  1. Edit arduino-1.0/hardware/arduino/boards.txt and add the following to the bottom (this is different than what Ryan posted earlier):
orangutan328.name=Pololu Orangutan or 3pi robot w/ ATmega328
orangutan328.upload.protocol=arduino
orangutan328.upload.maximum_size=32256
orangutan328.upload.speed=144000
orangutan328.bootloader.low_fuses=0xF6
orangutan328.bootloader.high_fuses=0xDE
orangutan328.bootloader.extended_fuses=0x05
orangutan328.bootloader.path=optiboot
orangutan328.bootloader.file=optiboot_atmega328.hex
orangutan328.bootloader.unlock_bits=0x3F
orangutan328.bootloader.lock_bits=0x0F
orangutan328.build.mcu=atmega328p
orangutan328.build.f_cpu=20000000L
orangutan328.build.core=arduino
orangutan328.build.variant=standard
  1. Edit programmers.txt in the same directory and add the following to the bottom:
avrispv2.name=AVR ISP v2
avrispv2.communication=serial
avrispv2.protocol=avrispv2
(This assumes that you are using our USB AVR programmer to load Optiboot on the Baby Orangutan. If you are using a different programmer, you can modify or skip this step as appropriate.)
  1. Cut the reset trace on the Baby Orangutan as indicated in Ben’s earlier post.
  2. Connect the Orangutan to the programmer and apply power.
  3. Open Arduino 1.0.
  4. In Tools > Board, select the entry for the Orangutan you added earlier.
  5. In Tools > Serial Port, select the USB AVR Programmer Programming Port.
  6. In Tools > Programmer, select the AVR ISP v2 entry you added earlier.
  7. Select Tools > Burn Bootloader. After this completes, you can disconnect the Orangutan from the programmer.
  8. Connect the Orangutan to your serial adapter. I used a 0.1 uF capacitor between DTR and the Orangutan’s RESET. (You should make sure the Orangutan is unpowered while you do this.)
    In Tools > Serial Port, select the port that your serial adapter is using. You should now be able to program the Orangutan using the bootloader with the Upload button.
For some reason, I did not run into the serial baud rate problem and did not have to replace WinAVR; maybe my different settings in boards.txt allowed me to avoid the problem. Let us know if these steps work for you.
- Kevin
