Will either of these run on Raspberry Pi 64 bit Linux? Which should I try first?
Jrk G2 Software for Linux (x86)(9MB xz) — works on 32-bit and 64-bit systems
Jrk G2 Software for Linux (Raspberry Pi)
If you are using a Raspberry Pi, you should use the “Jrk G2 Software for Linux (Raspberry Pi)” version of the Jrk G2 software. As mentioned in the “Installing Linux software” section of the Jrk G2 user’s guide, that version works on the Raspberry Pi (and might work on other ARM Linux systems).
Even though I’m running 64 bit OS?
Yes. While the “Jrk G2 Software for Linux (Raspberry Pi)” version was compiled for 32-bit Raspberry Pis, we expect it to work fine on 64-bit ones as well.
The software does appear to work fine on Rapsberry Pi 64 bit Linux.
I am communicating with the board…have not controlled motor yet.
