Could you please let me know the dimensions and weight of the assembled product (including the female headers and the blue terminal blocks) in mm and g? Thanks
I measured one of our VNH5019 motor driver shields with the headers and terminal blocks installed at about 65mm L X 51.3mm W X 20mm H. The weight was about 28g. Please note your weight might vary by the options you install and the amount of solder you use. Also note, the height measurement is from the tallest component to the tip of the extended female header wires, the height without the extended header wires is about 11.5mm.
-Derrill
That is excellent! Thank you Derrill.
