Im trying to measure velocity of a DC motor equipped with an optical encoder while using the Dual VNH5019 motor shield and an Arduino Mega2560. The program reads the correct velocity when the motor is running at full speed but the motor wont run at any other speed. When the timer section is commented out the motor will run at any speed and still make the correct counts and angle measurements but not velocity since the timer is commented out. The code is shown below. Im using timer 2 with a 64 prescale and channel A from the encoder is sent to pin 3 and channel B from encoder is sent to pin 5.
Does the arduino and the motor shield have the capabilities to perform these functions alone or do I need a separate encoder shield?
[code]#include “DualVNH5019MotorShield.h”
DualVNH5019MotorShield md;
// for encoder 0
#define encoder0PinA 3
#define encoder0PinB 5
volatile long encoder0Count = 0;
volatile float angle0 = 0;
volatile float velocity0 = 0;
volatile float angle0_previous = 0;
volatile float angle0_post = 0;
// for Timer2
volatile int tcnt2 = 0;
volatile int t = 0;
void setup() {
// for encoder 0
pinMode(encoder0PinA, INPUT);
pinMode(encoder0PinB, INPUT);
//attachInterrupt(0, doEncoder0A, CHANGE);
attachInterrupt(1, doEncoder0B, CHANGE);
//setup for Timer2: interrupts every 1 ms
TIMSK2 &= ~(1<<TOIE2);
TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
TCCR2B &= ~(1<<WGM22);
ASSR &= ~(1<<AS2);
//OCR2A = 249;// =(16000000/1000*64)-1 must be>256
TIMSK2 &= ~(1<<OCIE2A);
TCCR2B &= ~(1<<CS21) | (1<<CS20); //64 prescaler
TCCR2B |= (1<<CS22); //64 prescaler
TCNT2 = tcnt2;
TIMSK2 |= (1<<TOIE2);
Serial.begin (115200); // for debugging
void loop() {
md.setM2Speed(175);
// for encoder 0
Serial.print("cnt0: “);
Serial.print(encoder0Count, DEC);
Serial.print(”; ");
Serial.print("agl0: “);
Serial.print(angle0, 4);
Serial.print(”; ");
Serial.print("vel0: “);
Serial.print(velocity0, 4);
Serial.println(”. ");
//delay(500);
void doEncoder0B(){ // interrupt 1 function
if (digitalRead(encoder0PinB) == HIGH) { // look for a low-to-high on channel B
if (digitalRead(encoder0PinA) == HIGH) { // check channel A to see which way encoder is turning
encoder0Count = encoder0Count + 1;
else {
encoder0Count = encoder0Count - 1;
else { // must be a high-to-low edge on on channel B
if (digitalRead(encoder0PinA) == LOW) { // check channel B to see which way encoder is turning
else {
angle0 = 0.36*encoder0Count; // unit: degree
// estimate velocity
ISR(TIMER2_OVF_vect) {
TCNT1 = tcnt2; // reload the timer
t++;
if (t == 1){
angle0_previous = angle0;
else if (t == 20){
angle0_post = angle0;
else if (t == 21){
velocity0 = (angle0_post - angle0_previous)*8.333; // unit: rpm
t = 0;
}[/code]
