I have searched and read a few threads related to M2 fault on the VNH5019 Dual controller.
First off i will try to briefly describe my problem, then what i have done so far and where i am at.
When i load the demo code provided with the arduino library I get a m2 fault. I tried it on a UNO and a Diecimiela(sp). Same results both boards.
From there i began searching the forums. I came across the following thread.
There is a great photo with a description of how to measure continuity between various points. I did this and found everything to be fine.
From there i wrote a simple sketch to test each motor.
First i tested M1 with this(sorry for any mistakes as this is off the top of my head and the actual code is on a different computer)
void(){
md.setM1Speed(150);
delay(500);
md.setM2Speed(-150);
delay(500);}
I also left in code telling it to stop if any faults were found (copied from the demo sketch)
This worked fine.
Then i did the same thing for motor 2. This caused a fault and the code stopped as it should have with a M2 fault.
I commented out the code telling it to stop upon a fault and the motor ran exactly as it should.
My concern is that a fault is showing up. I currently do not have a working probe for my scope so i cant look at the output on a scope currently. in a few days i am going to be torn away from this project for a couple of months but hopefully i can get pointed in the right direction so when i pick this back up in a couple of months i can finish troubleshooting this and move on.
If photos are needed/wanted i can provide but i may be slow at getting to them.
Thanks in advance for any help that can be provided.
