It is possible to trigger a subroutine within a script on the Maestro using a high or low input. You could the get_position and greater_than commands to check if the input is high and then the servo command to move the servo, as I wrote out below:
if
4000 1 servo
end if```
Since you are new to the Maestro, I recommend looking over the "The Maestro Scripting Language" section of the [Maestro user's guide](https://www.pololu.com/docs/0J40) for a list of all the commands and examples.
-Claire
