Thank you for the detailed reply.
Apologies for the delayed response; I was occupied with exams.
Regarding the earlier measurement of approximately 50V across the capacitor connected to Vin/GND, the reading was taken using a DMM (we are trying to procure an oscilloscope) while the system was actively running not during startup or shutdown. A few seconds later, using a different DMM, we obtained the expected nominal readings. While this may have been a measurement issue with the first DMM, the meter is relatively new and continues to function normally.
After this test, we powered the system off for around 10-20 minutes. When we turned it back on, the driver failed after approximately 30-40 seconds of operation. Specifically, it stopped powering the electromagnet.
Recently, we replaced the damaged MOSFET on the driver board. During inspection, we found that one MOSFET was damaged, and on another board, a capacitor was damaged as well. After replacing the faulty MOSFET (from the driver which has damaged capacitor), the driver started functioning again.
Regarding current calculations, we ensured that the operating current remains within the limits of the driver, booster, and SMPS supply. We have not tested beyond 36V since the driver failure occurred after operating at that voltage.
We have also ordered the following TVS diodes for protection testing with the electromagnet:
- STMicroelectronics 1.5KE43CA
- Littelfuse 1.5KE36CA
Once they arrive, we will integrate them into the setup (in parallel to the electromagnet, which may help in spikes saving the body MOSFETs) and perform additional tests.
I am attaching the circuit diagram, and here is the video link showing our setup in operation (although a different motor driver was used at 22V). The project involves levitating a permanent magnet using two electromagnets.
Video Link: https://drive.google.com/file/d/1_7Z_h4rb8UcV2RijKO80dnNMi7-6Y5Of/view
Thank you again for your guidance.
