Is it possible to power MCU with VMM of DRV8833. If so what is the output voltage at VMM. I’d like to power both the Motors and the MCU with a single battery source.
Thanks,
Thanks,
Yes, it is possible to power an MCU using the VMM pin. As described in the pinout table on the DRV8833 product page, VMM gives access to the motor power supply after the reverse-voltage protection MOSFET, so it can be used to supply reverse-protected power to other components in the system.
- Patrick
Thanks.
Would motor noise affect the arduino or other mcu when powered from vmm of drv8833?
Motors can generate a lot of electrical noise, and that has the potential to interfere with signals like the ones going to and from an Arduino regardless of how you are you are powering it. So, if you notice parts of your system behaving strangely when the motor is active you might consider some of these suggestions for decreasing the impact of motor-induced electrical noise:
Powering your microcontroller from the same source as your motor and driver does however introduce additional ways for the motor to affect it. For example, if your power supply is insufficient for the motor, then the motor’s inrush current when it starts up could cause the supply voltage to drop to a point where your microcontroller will brown out. (Suggestion 4 above can reduce the chances of that significantly though.)
- Patrick
Thanks.
