I find if I use the kill switch and tell it to goto a specific location it works as long as no other soft errors occur. Sadly the kill switch is interlinked to generic soft errors so if I use command timeout it will goto my position without kill. Kill needs to be an independent flag from soft error as I cannot find another way to disable safe start and auto home on power up. Any suggestions?
Hello, Jim.
I moved your post to its own thread since it sounded different enough from the thread it was in.
Can you clarify the problem you are having? What do you want the Tic to do and what is it doing instead? Also, could you post your settings file? You can save your settings file from the “File” drop-down menu in the Tic Control Center while the controller is connected.
