I am building a fly-by-wire throttle system and need to control a servo on a throttle body. I have a throttle body with what i assumed was a servo attached, but i discovered it was only a DC motor. There are two potentiometers on the output shaft, and they feed back to the ECU, which I unfortunately don’t have. I assume the ECU then provides a closed loop feedback to the motor to essentially turn it into a servo. While i’m sure i could do this with the Arduino i’m using, I am worried about the settling time and efficiency of my control system. Since this is going to be controlling the fuel going into an engine, I would like something a little more professional. I would like to avoid mounting a servo to the system, right now the DC motor is packaged really well and it would be a pain to mount a servo.
Would the JRK 21v3 work for this? It says it can provide closed loop feedback for position control, so it sounds like it to me. Does anyone have any recommendations?
Thanks!
