Can communicate but don’t get any motor LED response
Blue solid, red solid and green flashing but no motor LED activity
all jumpers removed except +=Vcc, and mix
Problem is likely with the code but the code is real simple and should work…
[code]
// Included for serial communication
#include <SoftwareSerial.h>
// Define pins you’re using for serial communication
// Do not use pins 0 or 1 as they are reserved for
// standard I/O and programming
#define TXPIN 4
#define RXPIN 5
// Create an instance of the software serial
// communication object. This represents the
// interface with the TReX Jr device
SoftwareSerial pololu(RXPIN, TXPIN);
// Main application entry point
void setup()
// Define the appropriate input/output pins
pinMode(RXPIN, INPUT);
pinMode(TXPIN, OUTPUT);
// Begin communicating with the pololu interface
Serial.begin(9600);
pololu.begin(19200);
delay(5);
// Main application loop
void loop()
// Loop through 127 to 0, forward
for(int i = 127; i >= 0; i–)
// Say that we are setting our speed
Serial.print("Setting speed 0 to: ");
Serial.println(i, DEC);
// Set speed to motor 0 and forward
SetSpeed(0, true, i);
delay(100);
Serial.print("Setting speed 1 to: ");
SetSpeed(1, true, i);
delay(10);
// Loop through 0 to 127, backward
for(int i = 0; i < 128; i++)
delay(100);
delay(100);
// Set the motor index, direction, and speed
// Motor index should either be a 0 or 1
// Direction should be either true for forward or false for backwards
// Speed should range between 0 and 127 (inclusivly)
void SetSpeed(int MotorIndex, boolean Forward, int Speed)
// Validate motor index
if(MotorIndex < 0 || MotorIndex > 2)
return;
// Validate speed
if(Speed < 0)
Speed = 0;
else if(Speed > 127)
Speed = 127;
// Send the “set” command based on the motor
// Note that we do not accelerate to the
// speed, we just instantly set it
unsigned char SendByte = 0;
if(MotorIndex == 0)
SendByte = 0xC2;
else if(MotorIndex == 1)
SendByte = 0xCA;
else if(MotorIndex == 2)
SendByte = 0xF0;
// If we go backwards, the commands are the same
// but minus one
if(!Forward)
SendByte–;
// Send the set speed command byte
//pololu.write(SendByte);
// Send the speed data byte
pololu.write(Speed);
}[/code]
