Hello Polulu Support team,
We are using various Pololu Tic for quite some time now. Until now mainly the 36v4. Recently we started to use the T825. However, we are having issues to disable the timeout with the T825 with firmware 1.06. Until now we were using the following Python lines according to the Pololu USB documentation to set the timeout setting to 0s:
if int.from_bytes(self.device.ctrl_transfer(0xC0, 0xA8, 0x00, 0x09, 2), ‘little’) != 0:
self.device.ctrl_transfer(0x40, 0x13, 0, 0x09, 0, None)
self.device.ctrl_transfer(0x40, 0x13, 0, 0x0A, 0, None)
log.info(f’Command timeout was deactivated’)
As far as I understand, the procedure did not change for the T825. But it doesn’t work anymore. While usb reverse engineering the bytes sent by Tic control center I have not found any commando frames containing 40:13:00:09. Did I miss something about the T825? Can you help me?
Constantly sending the ‘reset commando timeout’ 0x8c is not an option for us.
Thank you for your help in advance!
