Hi All
Using Beaglebone black with latest Debian Stretch Lxqt desktop.
Can someone tell me (before I start installing) which package is correct:
Linux (x86) or the Rpi version.
Regards
Dinosaur
Hi All
Regards
Dinosaur
The BeagleBone Black uses an ARM processor, so the x86 version of the Tic software would not work. The Raspberry Pi version of the Tic Software might work on the BeagleBone Black.
- Amanda
Hi All
Thanks for the reply, I did read that on your website, BUT hoped someone had already tried that.
Just means uninstalling when it doesn’t work.
Will just use the 86 version on the laptop and set it up before connecting to the BBB.
Regards
Dinosaur
Edit:
ls -la
-rwxr-xr-x 1 barfresh barfresh 1636384 Jan 30 18:13 ticcmd
-rwxr-xr-x 1 barfresh barfresh 22208400 Jan 30 18:13 ticgui
Hi All
Well it is not that easy after all.
Ran sudo ./install.sh and it copied the 99-polulu.rules to /etc/udev/rules.d
Rebooted and plugged in the T249.
Result is that:
Red led is full on.
Amber led is flashing at about 1 sec.
Green led is flashing at about 1 sec.
Checked my rules files and decided that having 2 x 99 rules files could be the problem.
So added the line from my 99-polulu.rules to my other .rules file (which works).
Deleted the 99-polulu.rules and rebooted.
Same result.
The ticgui program is all greyed out and shows “Not connected”
Any suggestions ?
Regards
Dinosaur
It seems like your Linux machine might not be detecting the Tic T249 stepper motor controller device. Can you run lsusb and post the results here? Also, can you run dmesg right after plugging in the Tic and post the entire output as well?
- Amanda
Hi All
lsusb output:
barfresh@jvp ~/Downloads/pololu-tic-1.7.0-linux-x86 $ lsusb
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 005: ID 04f2:b3f6 Chicony Electronics Co., Ltd HD WebCam (Acer)
Bus 002 Device 004: ID 04f3:0261 Elan Microelectronics Corp.
Bus 002 Device 003: ID 0489:e04e Foxconn / Hon Hai
Bus 002 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg:
[ 0.000000] PM: Registered nosave memory: [mem 0x9fa00000-0xdfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfe100fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfe101000-0xfe112fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfe113000-0xfeafffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfeb00000-0xfeb0ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfeb10000-0xfebfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xffbfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xffc00000-0xffffffff]
[ 0.000000] e820: [mem 0x9fa00000-0xdfffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] random: get_random_bytes called from start_kernel+0x99/0x51b with crng_init=0
[ 0.000000] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] percpu: Embedded 46 pages/cpu @ (ptrval) s151552 r8192 d28672 u262144
[ 0.000000] pcpu-alloc: s151552 r8192 d28672 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1001907
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-39-generic root=UUID=804f12f6-66fd-4fad-825b-a8a98286f773 ro quiet splash vt.handoff=7
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 3785628K/4071704K available (12300K kernel code, 2471K rwdata, 4260K rodata, 2408K init, 2416K bss, 286076K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Kernel/User page tables isolation: enabled
[ 0.000000] ftrace: allocating 39184 entries in 154 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 524544, nr_irqs: 760, preallocated irqs: 16
[ 0.000000] vt handoff: transparent VT on vt#7
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] ACPI: Core revision 20170831
[ 0.000000] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] APIC: Switch to symmetric I/O mode setup
[ 0.000000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.020000] tsc: Fast TSC calibration using PIT
[ 0.024000] tsc: Detected 2294.600 MHz processor
[ 0.024000] Calibrating delay loop (skipped), value calculated using timer frequency.. 4589.20 BogoMIPS (lpj=9178400)
[ 0.024000] pid_max: default: 32768 minimum: 301
[ 0.028942] Security Framework initialized
[ 0.028944] Yama: becoming mindful.
[ 0.028970] AppArmor: AppArmor initialized
[ 0.029648] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.032268] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.032297] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.032311] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.032534] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.032534] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.032539] mce: CPU supports 7 MCE banks
[ 0.032548] CPU0: Thermal monitoring enabled (TM1)
[ 0.032559] process: using mwait in idle threads
[ 0.032562] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[ 0.032562] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[ 0.032564] Spectre V2 : Mitigation: Full generic retpoline
[ 0.032565] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.032565] Speculative Store Bypass: Vulnerable
[ 0.039124] Freeing SMP alternatives memory: 36K
[ 0.052000] smpboot: CPU0: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz (family: 0x6, model: 0x45, stepping: 0x1)
[ 0.052000] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.052000] ... version: 3
[ 0.052000] ... bit width: 48
[ 0.052000] ... generic registers: 4
[ 0.052000] ... value mask: 0000ffffffffffff
[ 0.052000] ... max period: 00007fffffffffff
[ 0.052000] ... fixed-purpose events: 3
[ 0.052000] ... event mask: 000000070000000f
[ 0.052000] Hierarchical SRCU implementation.
[ 0.052000] smp: Bringing up secondary CPUs ...
[ 0.052000] x86: Booting SMP configuration:
[ 0.052000] .... node #0, CPUs: #1
[ 0.052000] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.052000] #2 #3
[ 0.052000] smp: Brought up 1 node, 4 CPUs
[ 0.052000] smpboot: Max logical packages: 2
[ 0.052000] smpboot: Total of 4 processors activated (18356.80 BogoMIPS)
[ 0.052196] devtmpfs: initialized
[ 0.052196] x86/mm: Memory block size: 128MB
[ 0.052423] evm: security.selinux
[ 0.052423] evm: security.SMACK64
[ 0.052424] evm: security.SMACK64EXEC
[ 0.052424] evm: security.SMACK64TRANSMUTE
[ 0.052425] evm: security.SMACK64MMAP
[ 0.052425] evm: security.apparmor
[ 0.052426] evm: security.ima
[ 0.052426] evm: security.capability
[ 0.052442] PM: Registering ACPI NVS region [mem 0x9aebf000-0x9afbefff] (1048576 bytes)
[ 0.052442] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.052442] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.052442] pinctrl core: initialized pinctrl subsystem
[ 0.052442] RTC time: 21:20:23, date: 05/30/19
[ 0.052442] NET: Registered protocol family 16
[ 0.052442] audit: initializing netlink subsys (disabled)
[ 0.052442] audit: type=2000 audit(1559251223.052:1): state=initialized audit_enabled=0 res=1
[ 0.052442] cpuidle: using governor ladder
[ 0.056011] cpuidle: using governor menu
[ 0.056038] Simple Boot Flag at 0x44 set to 0x1
[ 0.056050] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.056052] ACPI: bus type PCI registered
[ 0.056053] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.056110] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.056116] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.056116] PCI: Using configuration type 1 for base access
[ 0.056118] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.057203] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.057203] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.057203] ACPI: Added _OSI(Module Device)
[ 0.057203] ACPI: Added _OSI(Processor Device)
[ 0.057203] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.057203] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.057203] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.057203] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.057203] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.066564] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.067931] ACPI: Dynamic OEM Table Load:
[ 0.067939] ACPI: SSDT 0xFFFF888659FFA000 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120913)
[ 0.068600] ACPI: Dynamic OEM Table Load:
[ 0.068606] ACPI: SSDT 0xFFFF888659FA0800 0005AA (v01 PmRef ApIst 00003000 INTL 20120913)
[ 0.069324] ACPI: Dynamic OEM Table Load:
[ 0.069329] ACPI: SSDT 0xFFFF888659833A00 000119 (v01 PmRef ApCst 00003000 INTL 20120913)
[ 0.070766] ACPI: EC: EC started
[ 0.070766] ACPI: EC: interrupt blocked
[ 0.116041] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[ 0.116044] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x22, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.116045] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
[ 0.116046] ACPI: Interpreter enabled
[ 0.116085] ACPI: (supports S0 S3 S4 S5)
[ 0.116086] ACPI: Using IOAPIC for interrupt routing
[ 0.116119] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.116575] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.192928] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.192934] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.193464] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.193466] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.194382] PCI host bridge to bus 0000:00
[ 0.194385] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.194387] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.194388] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.194390] pci_bus 0000:00: root bus resource [mem 0x9fa00000-0xfeafffff window]
[ 0.194391] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.194400] pci 0000:00:00.0: [8086:0a04] type 00 class 0x060000
[ 0.194621] pci 0000:00:02.0: [8086:0a16] type 00 class 0x030000
[ 0.194633] pci 0000:00:02.0: reg 0x10: [mem 0xb0000000-0xb03fffff 64bit]
[ 0.194639] pci 0000:00:02.0: reg 0x18: [mem 0xa0000000-0xafffffff 64bit pref]
[ 0.194644] pci 0000:00:02.0: reg 0x20: [io 0x3000-0x303f]
[ 0.194658] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.194855] pci 0000:00:03.0: [8086:0a0c] type 00 class 0x040300
[ 0.194865] pci 0000:00:03.0: reg 0x10: [mem 0xb0610000-0xb0613fff 64bit]
[ 0.195097] pci 0000:00:14.0: [8086:9c31] type 00 class 0x0c0330
[ 0.195116] pci 0000:00:14.0: reg 0x10: [mem 0xb0600000-0xb060ffff 64bit]
[ 0.195170] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.195365] pci 0000:00:16.0: [8086:9c3a] type 00 class 0x078000
[ 0.195386] pci 0000:00:16.0: reg 0x10: [mem 0xb0618000-0xb061801f 64bit]
[ 0.195451] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.195649] pci 0000:00:1b.0: [8086:9c20] type 00 class 0x040300
[ 0.195666] pci 0000:00:1b.0: reg 0x10: [mem 0xb0614000-0xb0617fff 64bit]
[ 0.195729] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.195924] pci 0000:00:1c.0: [8086:9c14] type 01 class 0x060400
[ 0.195990] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.196259] pci 0000:00:1c.3: [8086:9c16] type 01 class 0x060400
[ 0.196326] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.196531] pci 0000:00:1d.0: [8086:9c26] type 00 class 0x0c0320
[ 0.198340] pci 0000:00:1d.0: reg 0x10: [mem 0xb061c000-0xb061c3ff]
[ 0.199312] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.199512] pci 0000:00:1f.0: [8086:9c43] type 00 class 0x060100
[ 0.199811] pci 0000:00:1f.2: [8086:9c03] type 00 class 0x010601
[ 0.199826] pci 0000:00:1f.2: reg 0x10: [io 0x3088-0x308f]
[ 0.199832] pci 0000:00:1f.2: reg 0x14: [io 0x3094-0x3097]
[ 0.199838] pci 0000:00:1f.2: reg 0x18: [io 0x3080-0x3087]
[ 0.199845] pci 0000:00:1f.2: reg 0x1c: [io 0x3090-0x3093]
[ 0.199851] pci 0000:00:1f.2: reg 0x20: [io 0x3060-0x307f]
[ 0.199857] pci 0000:00:1f.2: reg 0x24: [mem 0xb061b000-0xb061b7ff]
[ 0.199889] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.200084] pci 0000:00:1f.3: [8086:9c22] type 00 class 0x0c0500
[ 0.200100] pci 0000:00:1f.3: reg 0x10: [mem 0xb0619000-0xb06190ff 64bit]
[ 0.200118] pci 0000:00:1f.3: reg 0x20: [io 0x3040-0x305f]
[ 0.200418] pci 0000:01:00.0: [14e4:16b3] type 00 class 0x020000
[ 0.200456] pci 0000:01:00.0: reg 0x10: [mem 0xb0410000-0xb041ffff 64bit pref]
[ 0.200475] pci 0000:01:00.0: reg 0x18: [mem 0xb0420000-0xb042ffff 64bit pref]
[ 0.200509] pci 0000:01:00.0: reg 0x30: [mem 0xfffff800-0xffffffff pref]
[ 0.200610] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.200722] pci 0000:01:00.1: [14e4:16bc] type 00 class 0x080501
[ 0.200758] pci 0000:01:00.1: reg 0x10: [mem 0xb0400000-0xb040ffff 64bit pref]
[ 0.200889] pci 0000:01:00.1: PME# supported from D0 D3hot D3cold
[ 0.212070] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.212078] pci 0000:00:1c.0: bridge window [mem 0xb0400000-0xb04fffff 64bit pref]
[ 0.212129] pci 0000:02:00.0: [168c:0034] type 00 class 0x028000
[ 0.212161] pci 0000:02:00.0: reg 0x10: [mem 0xb0500000-0xb057ffff 64bit]
[ 0.212211] pci 0000:02:00.0: reg 0x30: [mem 0xffff0000-0xffffffff pref]
[ 0.212281] pci 0000:02:00.0: supports D1 D2
[ 0.212282] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.224031] pci 0000:00:1c.3: PCI bridge to [bus 02]
[ 0.224035] pci 0000:00:1c.3: bridge window [mem 0xb0500000-0xb05fffff]
[ 0.232927] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *7
[ 0.233002] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.233076] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.233148] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.233220] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.233292] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.233365] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.233438] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.233756] ACPI: EC: interrupt unblocked
[ 0.233764] ACPI: EC: event unblocked
[ 0.233784] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x22, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.233785] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
[ 0.233998] SCSI subsystem initialized
[ 0.234013] libata version 3.00 loaded.
[ 0.234013] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.234013] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.234013] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.234013] vgaarb: loaded
[ 0.234013] ACPI: bus type USB registered
[ 0.234013] usbcore: registered new interface driver usbfs
[ 0.234013] usbcore: registered new interface driver hub
[ 0.234013] usbcore: registered new device driver usb
[ 0.234013] EDAC MC: Ver: 3.0.0
[ 0.234013] Registered efivars operations
[ 0.264082] PCI: Using ACPI for IRQ routing
[ 0.267861] PCI: pci_cache_line_size set to 64 bytes
[ 0.267955] e820: reserve RAM buffer [mem 0x0006f000-0x0006ffff]
[ 0.267956] e820: reserve RAM buffer [mem 0x00088000-0x0008ffff]
[ 0.267957] e820: reserve RAM buffer [mem 0x94cb0000-0x97ffffff]
[ 0.267958] e820: reserve RAM buffer [mem 0x9a6bf000-0x9bffffff]
[ 0.267960] e820: reserve RAM buffer [mem 0x9b000000-0x9bffffff]
[ 0.267961] e820: reserve RAM buffer [mem 0x15f600000-0x15fffffff]
[ 0.268062] NetLabel: Initializing
[ 0.268063] NetLabel: domain hash size = 128
[ 0.268063] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.268078] NetLabel: unlabeled traffic allowed by default
[ 0.268093] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.268093] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.270066] clocksource: Switched to clocksource hpet
[ 0.278144] VFS: Disk quotas dquot_6.6.0
[ 0.278163] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.278269] AppArmor: AppArmor Filesystem Enabled
[ 0.278296] pnp: PnP ACPI init
[ 0.278515] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.278517] system 00:00: [io 0xfd60-0xfd63] has been reserved
[ 0.278519] system 00:00: [io 0xffff] has been reserved
[ 0.278521] system 00:00: [io 0xffff] has been reserved
[ 0.278522] system 00:00: [io 0xffff] has been reserved
[ 0.278524] system 00:00: [io 0x1800-0x18fe] has been reserved
[ 0.278525] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.278531] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.278589] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.278649] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.278653] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.278685] pnp 00:03: Plug and Play ACPI device, IDs MSF0001 PNP0303 (active)
[ 0.278847] pnp 00:04: Plug and Play ACPI device, IDs ETD0500 PNP0f13 (active)
[ 0.284208] pnp 00:05: disabling [mem 0xffffffff-0x10000fffe] because it overlaps 0000:01:00.0 BAR 6 [mem 0xfffff800-0xffffffff pref]
[ 0.284212] pnp 00:05: disabling [mem 0xffffffff-0x10000fffe disabled] because it overlaps 0000:02:00.0 BAR 6 [mem 0xffff0000-0xffffffff pref]
[ 0.284235] system 00:05: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.284237] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.284238] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.284240] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.284242] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.284243] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.284245] system 00:05: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.284246] system 00:05: [mem 0xff000000-0xff000fff] has been reserved
[ 0.284248] system 00:05: [mem 0xff010000-0xffffffff] could not be reserved
[ 0.284250] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.284252] system 00:05: [mem 0x9fa20000-0x9fa20fff] has been reserved
[ 0.284256] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.284661] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.285355] pnp: PnP ACPI: found 7 devices
[ 0.291321] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.291326] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfffff800-0xffffffff pref]: no compatible bridge window
[ 0.291328] pci 0000:02:00.0: can't claim BAR 6 [mem 0xffff0000-0xffffffff pref]: no compatible bridge window
[ 0.291348] pci 0000:00:1c.0: BAR 14: assigned [mem 0x9fb00000-0x9fbfffff]
[ 0.291351] pci 0000:01:00.0: BAR 6: assigned [mem 0x9fb00000-0x9fb007ff pref]
[ 0.291353] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.291358] pci 0000:00:1c.0: bridge window [mem 0x9fb00000-0x9fbfffff]
[ 0.291361] pci 0000:00:1c.0: bridge window [mem 0xb0400000-0xb04fffff 64bit pref]
[ 0.291366] pci 0000:02:00.0: BAR 6: assigned [mem 0xb0580000-0xb058ffff pref]
[ 0.291368] pci 0000:00:1c.3: PCI bridge to [bus 02]
[ 0.291371] pci 0000:00:1c.3: bridge window [mem 0xb0500000-0xb05fffff]
[ 0.291379] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.291380] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.291382] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.291383] pci_bus 0000:00: resource 7 [mem 0x9fa00000-0xfeafffff window]
[ 0.291385] pci_bus 0000:01: resource 1 [mem 0x9fb00000-0x9fbfffff]
[ 0.291387] pci_bus 0000:01: resource 2 [mem 0xb0400000-0xb04fffff 64bit pref]
[ 0.291388] pci_bus 0000:02: resource 1 [mem 0xb0500000-0xb05fffff]
[ 0.291557] NET: Registered protocol family 2
[ 0.291765] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.291830] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.291926] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.291964] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.291979] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.292039] NET: Registered protocol family 1
[ 0.292052] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.312180] PCI: CLS 64 bytes, default 64
[ 0.312214] Unpacking initramfs...
[ 1.180875] Freeing initrd memory: 54236K
[ 1.180914] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.180917] software IO TLB [mem 0x8f0c0000-0x930c0000] (64MB) mapped at [ (ptrval)- (ptrval)]
[ 1.181177] Scanning for low memory corruption every 60 seconds
[ 1.181837] Initialise system trusted keyrings
[ 1.181846] Key type blacklist registered
[ 1.181885] workingset: timestamp_bits=36 max_order=20 bucket_order=0
[ 1.182996] zbud: loaded
[ 1.183498] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.183629] fuse init (API version 7.26)
[ 1.184851] Key type asymmetric registered
[ 1.184852] Asymmetric key parser 'x509' registered
[ 1.184889] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.184921] io scheduler noop registered
[ 1.184921] io scheduler deadline registered
[ 1.184964] io scheduler cfq registered (default)
[ 1.185485] pcieport 0000:00:1c.0: Signaling PME with IRQ 40
[ 1.185502] pcieport 0000:00:1c.3: Signaling PME with IRQ 41
[ 1.185567] efifb: probing for efifb
[ 1.185578] efifb: framebuffer at 0xa0000000, using 4160k, total 4160k
[ 1.185579] efifb: mode is 1366x768x32, linelength=5504, pages=1
[ 1.185579] efifb: scrolling: redraw
[ 1.185581] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.185658] Console: switching to colour frame buffer device 170x48
[ 1.185674] fb0: EFI VGA frame buffer device
[ 1.185682] intel_idle: MWAIT substates: 0x11142120
[ 1.185683] intel_idle: v0.4.1 model 0x45
[ 1.185865] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.185984] ACPI: AC Adapter [ACAD] (on-line)
[ 1.186049] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0D:00/input/input0
[ 1.186057] ACPI: Lid Switch [LID0]
[ 1.186087] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input1
[ 1.186095] ACPI: Power Button [PWRB]
[ 1.186123] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0E:00/input/input2
[ 1.186130] ACPI: Sleep Button [SLPB]
[ 1.186172] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 1.186195] ACPI: Power Button [PWRF]
[ 1.186627] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.248121] [Firmware Bug]: battery: (dis)charge rate invalid.
[ 1.248171] ACPI: Battery Slot [BAT1] (battery present)
[ 1.248495] Linux agpgart interface v0.103
[ 1.250436] loop: module loaded
[ 1.250595] libphy: Fixed MDIO Bus: probed
[ 1.250595] tun: Universal TUN/TAP device driver, 1.6
[ 1.250634] PPP generic driver version 2.4.2
[ 1.250682] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.250684] ehci-pci: EHCI PCI platform driver
[ 1.250828] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 1.250833] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 1.250844] ehci-pci 0000:00:1d.0: debug port 2
[ 1.254732] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 1.254744] ehci-pci 0000:00:1d.0: irq 23, io mem 0xb061c000
[ 1.268015] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.268056] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.268058] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.268059] usb usb1: Product: EHCI Host Controller
[ 1.268061] usb usb1: Manufacturer: Linux 4.15.0-39-generic ehci_hcd
[ 1.268062] usb usb1: SerialNumber: 0000:00:1d.0
[ 1.268182] hub 1-0:1.0: USB hub found
[ 1.268187] hub 1-0:1.0: 2 ports detected
[ 1.268324] ehci-platform: EHCI generic platform driver
[ 1.268333] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.268336] ohci-pci: OHCI PCI platform driver
[ 1.268345] ohci-platform: OHCI generic platform driver
[ 1.268350] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.268488] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.268492] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.269550] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0004b810
[ 1.269554] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.269660] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.269661] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.269663] usb usb2: Product: xHCI Host Controller
[ 1.269664] usb usb2: Manufacturer: Linux 4.15.0-39-generic xhci-hcd
[ 1.269665] usb usb2: SerialNumber: 0000:00:14.0
[ 1.269774] hub 2-0:1.0: USB hub found
[ 1.269783] hub 2-0:1.0: 9 ports detected
[ 1.271630] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.271634] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.271636] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.271663] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.271665] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.271666] usb usb3: Product: xHCI Host Controller
[ 1.271667] usb usb3: Manufacturer: Linux 4.15.0-39-generic xhci-hcd
[ 1.271669] usb usb3: SerialNumber: 0000:00:14.0
[ 1.271774] hub 3-0:1.0: USB hub found
[ 1.271781] hub 3-0:1.0: 4 ports detected
[ 1.272231] i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
[ 1.288106] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.288110] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.288252] mousedev: PS/2 mouse device common for all mice
[ 1.288921] rtc_cmos 00:01: RTC can wake from S4
[ 1.289030] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.289054] rtc_cmos 00:01: alarms up to one month, 242 bytes nvram, hpet irqs
[ 1.289060] i2c /dev entries driver
[ 1.289064] pcie_mp2_amd: AMD(R) PCI-E MP2 Communication Driver Version: 1.0
[ 1.289128] device-mapper: uevent: version 1.0.3
[ 1.289205] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[ 1.289212] intel_pstate: Intel P-state driver initializing
[ 1.289410] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.289412] EFI Variables Facility v0.08 2004-May-17
[ 1.310011] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 1.313396] NET: Registered protocol family 10
[ 1.318364] Segment Routing with IPv6
[ 1.318384] NET: Registered protocol family 17
[ 1.318420] Key type dns_resolver registered
[ 1.320591] RAS: Correctable Errors collector initialized.
[ 1.320624] microcode: sig=0x40651, pf=0x40, revision=0x17
[ 1.320678] microcode: Microcode Update Driver: v2.2.
[ 1.320686] sched_clock: Marking stable (1320674435, 0)->(1763507961, -442833526)
[ 1.320889] registered taskstats version 1
[ 1.320900] Loading compiled-in X.509 certificates
[ 1.323794] Loaded X.509 cert 'Build time autogenerated kernel key: b6bf907933a495504ab8d1400074f4a81bd9957f'
[ 1.325197] Loaded UEFI:db cert 'Acer: c4f0474ae6b5e67a509d99132f49a4ec13f7ac68' linked to secondary sys keyring
[ 1.325220] Loaded UEFI:db cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53' linked to secondary sys keyring
[ 1.325242] Loaded UEFI:db cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4' linked to secondary sys keyring
[ 1.325246] Problem loading UEFI:db X.509 certificate (-65)
[ 1.325250] Problem loading UEFI:db X.509 certificate (-65)
[ 1.325517] Couldn't get size: 0x800000000000000e
[ 1.325519] MODSIGN: Couldn't get UEFI MokListRT
[ 1.326213] zswap: loaded using pool lzo/zbud
[ 1.333054] Key type big_key registered
[ 1.333058] Key type trusted registered
[ 1.335142] Key type encrypted registered
[ 1.335145] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.335147] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[ 1.335151] ima: Allocated hash algorithm: sha1
[ 1.335168] evm: HMAC attrs: 0x1
[ 1.335478] Magic number: 3:748:349
[ 1.335587] rtc_cmos 00:01: setting system clock to 2019-05-30 21:20:25 UTC (1559251225)
[ 1.335631] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.335631] EDD information not available.
[ 1.604031] usb 2-2: new full-speed USB device number 2 using xhci_hcd
[ 1.604045] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.705660] Freeing unused kernel memory: 2408K
[ 1.736087] Write protecting the kernel read-only data: 20480k
[ 1.737253] Freeing unused kernel memory: 2008K
[ 1.741114] Freeing unused kernel memory: 1884K
[ 1.747485] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.747485] x86/mm: Checking user space page tables
[ 1.753747] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.755683] usb 2-2: New USB device found, idVendor=046d, idProduct=c52f
[ 1.755685] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.755687] usb 2-2: Product: USB Receiver
[ 1.755688] usb 2-2: Manufacturer: Logitech
[ 1.764429] usb 1-1: New USB device found, idVendor=8087, idProduct=8000
[ 1.764431] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.764594] hub 1-1:1.0: USB hub found
[ 1.764677] hub 1-1:1.0: 8 ports detected
[ 1.765893] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.766013] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.766030] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.848486] pps_core: LinuxPPS API ver. 1 registered
[ 1.848487] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.849670] PTP clock support registered
[ 1.850026] ahci 0000:00:1f.2: version 3.0
[ 1.850211] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 1.850616] sdhci: Secure Digital Host Controller Interface driver
[ 1.850617] sdhci: Copyright(c) Pierre Ossman
[ 1.853658] sdhci-pci 0000:01:00.1: SDHCI controller found [14e4:16bc] (rev 1)
[ 1.857875] mmc0: SDHCI controller on PCI [0000:01:00.1] using ADMA 64-bit
[ 1.858044] tg3.c:v3.137 (May 11, 2014)
[ 1.860290] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x3 impl SATA mode
[ 1.860294] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo only pio slum part deso sadm sds apst
[ 1.861250] scsi host0: ahci
[ 1.864222] scsi host1: ahci
[ 1.864356] scsi host2: ahci
[ 1.864831] scsi host3: ahci
[ 1.864893] ata1: SATA max UDMA/133 abar m2048@0xb061b000 port 0xb061b100 irq 43
[ 1.864896] ata2: SATA max UDMA/133 abar m2048@0xb061b000 port 0xb061b180 irq 43
[ 1.864897] ata3: DUMMY
[ 1.864898] ata4: DUMMY
[ 1.876097] tg3 0000:01:00.0 eth0: Tigon3 [partno(BCM57786) rev 57766001] (PCI Express) MAC address 20:1a:06:d2:e7:ab
[ 1.876101] tg3 0000:01:00.0 eth0: attached PHY is 57765 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 1.876103] tg3 0000:01:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.876106] tg3 0000:01:00.0 eth0: dma_rwctrl[00000001] dma_mask[64-bit]
[ 1.884039] usb 2-5: new full-speed USB device number 3 using xhci_hcd
[ 1.894207] tg3 0000:01:00.0 enp1s0f0: renamed from eth0
[ 1.906011] [drm] Memory usable by graphics device = 2048M
[ 1.906014] checking generic (a0000000 410000) vs hw (a0000000 10000000)
[ 1.906015] fb: switching to inteldrmfb from EFI VGA
[ 1.906045] Console: switching to colour dummy device 80x25
[ 1.906149] [drm] Replacing VGA console driver
[ 1.912118] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.912119] [drm] Driver supports precise vblank timestamp query.
[ 1.914210] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.924521] [drm] Initialized i915 1.6.0 20171023 for 0000:00:02.0 on minor 0
[ 1.926695] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 1.926940] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8
[ 2.053583] usb 2-5: string descriptor 0 read error: -22
[ 2.053589] usb 2-5: New USB device found, idVendor=0489, idProduct=e04e
[ 2.053590] usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.179502] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.180303] ata1.00: ATA-8: ST500LT012-9WS142, 0001SDM1, max UDMA/133
[ 2.180305] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.181204] ata1.00: configured for UDMA/133
[ 2.181441] scsi 0:0:0:0: Direct-Access ATA ST500LT012-9WS14 SDM1 PQ: 0 ANSI: 5
[ 2.181806] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.181886] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 2.181887] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.181906] sd 0:0:0:0: [sda] Write Protect is off
[ 2.181909] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.181939] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.184052] usb 2-7: new full-speed USB device number 4 using xhci_hcd
[ 2.208047] tsc: Refined TSC clocksource calibration: 2294.687 MHz
[ 2.208052] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x21139a22526, max_idle_ns: 440795252169 ns
[ 2.227820] sda: sda1 sda2 sda3
[ 2.228228] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.376857] fbcon: inteldrmfb (fb0) is primary device
[ 2.376910] Console: switching to colour frame buffer device 170x48
[ 2.376926] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 2.495470] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.497765] ata2.00: ATAPI: HL-DT-ST DVDRAM GUA0N, 1.00, max UDMA/133
[ 2.499345] ata2.00: configured for UDMA/133
[ 2.504213] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GUA0N 1.00 PQ: 0 ANSI: 5
[ 2.568691] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.568693] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.568868] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.568948] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.657990] random: fast init done
[ 2.744831] psmouse serio1: elantech: assuming hardware version 3 (with firmware version 0x454f00)
[ 2.772070] psmouse serio1: elantech: Synaptics capabilities query result 0x79, 0x16, 0x0c.
[ 2.812194] psmouse serio1: elantech: Elan sample query result 03, 64, 75
[ 2.941155] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input7
[ 3.232201] clocksource: Switched to clocksource tsc
[ 7.393234] usb 2-7: New USB device found, idVendor=04f3, idProduct=0261
[ 7.393236] usb 2-7: New USB device strings: Mfr=4, Product=14, SerialNumber=0
[ 7.393238] usb 2-7: Product: Touchscreen
[ 7.393239] usb 2-7: Manufacturer: ELAN
[ 7.520112] usb 2-8: new high-speed USB device number 5 using xhci_hcd
[ 7.703392] usb 2-8: New USB device found, idVendor=04f2, idProduct=b3f6
[ 7.703394] usb 2-8: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 7.703396] usb 2-8: Product: HD WebCam
[ 7.703397] usb 2-8: Manufacturer: Chicony Electronics Co.,Ltd.
[ 7.703399] usb 2-8: SerialNumber: 0001
[ 7.709589] hidraw: raw HID events driver (C) Jiri Kosina
[ 7.719006] usbcore: registered new interface driver usbhid
[ 7.719008] usbhid: USB HID core driver
[ 7.721181] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:046D:C52F.0001/input/input9
[ 7.721269] hid-generic 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-2/input0
[ 7.721442] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:046D:C52F.0002/input/input10
[ 7.780279] hid-generic 0003:046D:C52F.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input1
[ 8.344055] raid6: sse2x1 gen() 7775 MB/s
[ 8.392050] raid6: sse2x1 xor() 6168 MB/s
[ 8.440055] raid6: sse2x2 gen() 10015 MB/s
[ 8.488038] raid6: sse2x2 xor() 6711 MB/s
[ 8.536052] raid6: sse2x4 gen() 11533 MB/s
[ 8.584051] raid6: sse2x4 xor() 8108 MB/s
[ 8.632051] raid6: avx2x1 gen() 15379 MB/s
[ 8.680037] raid6: avx2x1 xor() 11606 MB/s
[ 8.728050] raid6: avx2x2 gen() 17685 MB/s
[ 8.776052] raid6: avx2x2 xor() 12118 MB/s
[ 8.824038] raid6: avx2x4 gen() 20506 MB/s
[ 8.872038] raid6: avx2x4 xor() 15151 MB/s
[ 8.872039] raid6: using algorithm avx2x4 gen() 20506 MB/s
[ 8.872051] raid6: .... xor() 15151 MB/s, rmw enabled
[ 8.872052] raid6: using avx2x2 recovery algorithm
[ 8.875039] xor: automatically using best checksumming function avx
[ 8.891516] Btrfs loaded, crc32c=crc32c-intel
[ 9.276750] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.164541] random: crng init done
[ 10.164544] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.377438] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 11.396158] systemd[1]: Detected architecture x86-64.
[ 11.396628] systemd[1]: Set hostname to <jvp>.
[ 13.733243] systemd[1]: Reached target User and Group Name Lookups.
[ 13.733309] systemd[1]: Reached target Encrypted Volumes.
[ 13.733347] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 13.733389] systemd[1]: Listening on udev Control Socket.
[ 13.733415] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.733483] systemd[1]: Listening on Journal Audit Socket.
[ 13.733493] systemd[1]: Reached target Remote File Systems (Pre).
[ 14.746929] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 15.917604] systemd-journald[369]: Received request to flush runtime journal from PID 1
[ 16.082574] lp: driver loaded but no devices found
[ 16.196477] ppdev: user-space parallel port driver
[ 25.147722] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 25.187138] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 25.195796] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 25.239704] ath: phy0: ASPM enabled: 0x42
[ 25.239707] ath: EEPROM regdomain: 0x6c
[ 25.239708] ath: EEPROM indicates we should expect a direct regpair map
[ 25.239710] ath: Country alpha2 being used: 00
[ 25.239711] ath: Regpair used: 0x6c
[ 25.249970] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 25.250533] ieee80211 phy0: Atheros AR9462 Rev:2 mem=0xffff94fe00d80000, irq=19
[ 25.258638] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 25.274934] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC282: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 25.274939] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 25.274941] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 25.274943] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 25.274945] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 25.274947] snd_hda_codec_realtek hdaudioC1D0: Mic=0x1b
[ 25.285015] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11
[ 25.292971] acer_wmi: Acer Laptop ACPI-WMI Extras
[ 25.293000] acer_wmi: Function bitmap for Communication Button: 0x801
[ 25.293084] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 25.293086] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 25.293087] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 25.293088] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 25.293088] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 25.299136] input: Acer WMI hotkeys as /devices/virtual/input/input12
[ 25.317055] AVX2 version of gcm_enc/dec engaged.
[ 25.317056] AES CTR mode by8 optimization enabled
[ 25.336218] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input13
[ 25.336295] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input14
[ 25.336361] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input15
[ 25.336425] input: HDA Intel HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.0/sound/card0/input16
[ 25.336489] input: HDA Intel HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.0/sound/card0/input17
[ 25.379235] intel_rapl: Found RAPL domain package
[ 25.379237] intel_rapl: Found RAPL domain core
[ 25.379238] intel_rapl: Found RAPL domain uncore
[ 25.379239] intel_rapl: Found RAPL domain dram
[ 25.379243] intel_rapl: RAPL package 0 domain package locked by BIOS
[ 25.483464] Bluetooth: Core ver 2.22
[ 25.483485] NET: Registered protocol family 31
[ 25.483486] Bluetooth: HCI device and connection manager initialized
[ 25.483490] Bluetooth: HCI socket layer initialized
[ 25.483492] Bluetooth: L2CAP socket layer initialized
[ 25.483498] Bluetooth: SCO socket layer initialized
[ 25.492189] usbcore: registered new interface driver btusb
[ 25.494008] usbcore: registered new interface driver ath3k
[ 25.520399] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
[ 25.636583] media: Linux media interface: v0.10
[ 25.642941] Linux video capture interface: v2.00
[ 25.651006] uvcvideo: Found UVC 1.00 device HD WebCam (04f2:b3f6)
[ 25.652081] uvcvideo 2-8:1.0: Entity type for entity Extension 4 was not initialized!
[ 25.652083] uvcvideo 2-8:1.0: Entity type for entity Processing 2 was not initialized!
[ 25.652085] uvcvideo 2-8:1.0: Entity type for entity Camera 1 was not initialized!
[ 25.652147] input: HD WebCam: HD WebCam as /devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.0/input/input18
[ 25.652206] usbcore: registered new interface driver uvcvideo
[ 25.652207] USB Video Class driver (1.1.1)
[ 25.657994] input: ELAN Touchscreen as /devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/0003:04F3:0261.0003/input/input19
[ 25.658108] hid-multitouch 0003:04F3:0261.0003: input,hiddev1,hidraw2: USB HID v1.10 Device [ELAN Touchscreen] on usb-0000:00:14.0-7/input0
[ 26.299119] Adding 4071420k swap on /dev/sda3. Priority:-2 extents:1 across:4071420k FS
[ 26.908648] audit: type=1400 audit(1559251251.068:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=798 comm="apparmor_parser"
[ 26.908768] audit: type=1400 audit(1559251251.068:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=797 comm="apparmor_parser"
[ 26.910080] audit: type=1400 audit(1559251251.068:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=800 comm="apparmor_parser"
[ 26.910418] audit: type=1400 audit(1559251251.068:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=795 comm="apparmor_parser"
[ 26.910421] audit: type=1400 audit(1559251251.068:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=795 comm="apparmor_parser"
[ 26.910424] audit: type=1400 audit(1559251251.068:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=795 comm="apparmor_parser"
[ 26.910427] audit: type=1400 audit(1559251251.068:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=795 comm="apparmor_parser"
[ 26.911740] audit: type=1400 audit(1559251251.068:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=794 comm="apparmor_parser"
[ 26.911745] audit: type=1400 audit(1559251251.068:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=794 comm="apparmor_parser"
[ 26.911837] audit: type=1400 audit(1559251251.068:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=801 comm="apparmor_parser"
[ 27.481564] new mount options do not match the existing superblock, will be ignored
[ 27.983422] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 27.983425] Bluetooth: BNEP filters: protocol multicast
[ 27.983430] Bluetooth: BNEP socket layer initialized
[ 32.211082] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 32.222063] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 32.224741] IPv6: ADDRCONF(NETDEV_UP): enp1s0f0: link is not ready
[ 32.394926] IPv6: ADDRCONF(NETDEV_UP): enp1s0f0: link is not ready
[ 33.675316] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 34.000435] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 41.236959] wlp2s0: authenticate with d4:04:cd:4d:6c:64
[ 41.249702] wlp2s0: send auth to d4:04:cd:4d:6c:64 (try 1/3)
[ 41.250789] wlp2s0: authenticated
[ 41.252042] wlp2s0: associate with d4:04:cd:4d:6c:64 (try 1/3)
[ 41.253370] wlp2s0: RX AssocResp from d4:04:cd:4d:6c:64 (capab=0x1011 status=0 aid=2)
[ 41.253461] wlp2s0: associated
[ 41.253763] ath: EEPROM regdomain: 0x8348
[ 41.253764] ath: EEPROM indicates we should expect a country code
[ 41.253765] ath: doing EEPROM country->regdmn map search
[ 41.253766] ath: country maps to regdmn code: 0x3a
[ 41.253767] ath: Country alpha2 being used: US
[ 41.253768] ath: Regpair used: 0x3a
[ 41.253770] ath: regdomain 0x8348 dynamically updated by country IE
[ 41.278325] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 41.295836] wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by d4:04:cd:4d:6c:64
[ 53.481811] Bluetooth: RFCOMM TTY layer initialized
[ 53.481816] Bluetooth: RFCOMM socket layer initialized
[ 53.481822] Bluetooth: RFCOMM ver 1.11
Many thanks for your support.
Regards
Dinosaur
Hi All
Here a copy of my .rules file:
SUBSYSTEM==“tty”,SUBSYSTEMS==“usb”,ATTRS{idVendor}==“0403”,ATTRS{idProduct}==“6001”,SYMLINK+=“IA3125”
SUBSYSTEM==“tty”,SUBSYSTEMS==“usb”,ATTRS{idVendor}==“067b”,ATTRS{idProduct}==“2303”,SYMLINK+=“WaveCom”
SUBSYSTEM==“tty”,SUBSYSTEMS==“usb”,ATTRS{idVendor}==“10c4”,ATTRS{idProduct}==“ea60”,SYMLINK+=“Adam4561”
SUBSYSTEMS==“usb”,ATTRS{idVendor}==“0a07”,ATTRS{idProduct}==“0046”,SYMLINK+=“Ontrak1”,MODE=“0666”
SUBSYSTEMS==“usb”,ATTRS{idVendor}==“2890”,ATTRS{idProduct}==“0201”,MODE=“0666”
SUBSYSTEM==“usb”, ATTRS{idVendor}==“1ffb”, MODE=“0666”
The last line for the polulu does not have a idProduct
Is that the issue, cause I have never had a problem identifying a usb device before.
Regards
Dinosaur
FYI: I am having the same response on the BBB when I add the symlink line in the .rules file.
Hi All
Installed on a Win7 & Win8 machine, both with same problem.
So, got suspicious about my cables (I have 2) and neither will communicate with my Kindle
which has the same plug. Some of these are for charging only, but there is no indication on the lead what it is.???
Will get another cable this morning and update with results.
Hi All
That solved the problem.
Amanda, sorry for taking your time with such a amateurish oversight.
Regards
Dinosaur
Edit:
The other good news is that the Beaglebone Black Rev:C runs the Rpi GUI program and communicates with the board.
Time to play.
Great! I’m glad you figured out the issue; thank you for letting us know how you resolved it and that the Raspberry Pi version of the Tic Software works on the BeagleBone Black (Rev:C). I’m sure others will find that information helpful.
- Amanda
