I am trying to run the basic I2C TIC example sketches on ESP8266 for TIC1500. For any I2C example sketch and for any board, I get the error:
Soft WDT reset
alternating with:
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
I used these sketches and libraries a year ago and everything worked then. The TIC is connected with I2C and I have configured it with the control center. Do you know what could be wrong?
Thanks.
EDIT:
Here is the stack trace:
Soft WDT reset
>>>stack>>>
ctx: cont
sp: 3ffffda0 end: 3fffffc0 offset: 01a0
3fffff40: 3ffe868c 00000000 3ffee318 402012bd
3fffff50: 00000022 00000004 3ffee318 402011c0
3fffff60: 3fffdad0 00000064 3ffee308 3ffee4b4
3fffff70: 3fffdad0 00000064 3ffee308 402010fc
3fffff80: 00000000 3ffee44c 3ffee308 40204125
3fffff90: 3fffdad0 3ffee44c 3ffee308 4020115a
3fffffa0: feefeffe 00000000 3ffee474 40201eb4
3fffffb0: feefeffe feefeffe 3ffe84e8 40100e11
<<<stack<<<
Here is what the exception decoder says:
0x402012bd: TicI2C::getSegment(TicCommand, unsigned char, unsigned char, void*) at C:\Users\perigalacticon\Documents\Arduino\libraries\Tic\Tic.cpp line 211
0x402011c0: TicI2C::commandQuick(TicCommand) at C:\Users\perigalacticon\Documents\Arduino\libraries\Tic\Tic.cpp line 184
0x402010fc: waitForPosition(int) at C:\Users\perigalacticon\Documents\Arduino\libraries\Tic/Tic.h line 1346
0x40204125: TicBase::setTargetPosition(int) at C:\Users\perigalacticon\Documents\Arduino\libraries\Tic/Tic.h line 348
0x4020115a: loop() at C:\Users\perigalacticon\Documents\Arduino\sketches\Modified Examples\I2CPositionControl_mod/I2CPositionControl_mod.ino line 90
0x40201eb4: loop_wrapper() at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_main.cpp line 197
The last line of code is 211 from Tic.cpp:
_lastError = Wire.endTransmission(false); // no stop (repeated start)
Sometimes the stack gives a different line:
0x4020259e: Twi::write_bit(bool) at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\core_esp8266_si2c.cpp line 282
