Hi there,
I was using Tic 500 Stepper motor controller with my older Arduino Nano and it was working just fine.
I have upgraded to new Arduino Nano 33 BLE. I tried to compile one of the examples.
This are the error messages
Arduino: 1.8.15 (Windows 10), Board: "Arduino Nano 33 BLE"
In file included from C:\Users\GEORGE\Documents\Arduino\sketch_jun20a\sketch_jun20a.ino:17:0:
C:\Users\GEORGE\Documents\Arduino\libraries\Tic/Tic.h: In member function 'void TicBase::setAgcBottomCurrentLimit(TicAgcBottomCurrentLimit)':
C:\Users\GEORGE\Documents\Arduino\libraries\Tic/Tic.h:688:63: warning: suggest parentheses around arithmetic in operand of '|' [-Wparentheses]
commandW7(TicCommand::SetAgcOption, 0x10 | (uint8_t)limit & 0xF);
C:\Users\GEORGE\Documents\Arduino\libraries\Tic/Tic.h: In member function 'void TicBase::setAgcCurrentBoostSteps(TicAgcCurrentBoostSteps)':
C:\Users\GEORGE\Documents\Arduino\libraries\Tic/Tic.h:698:63: warning: suggest parentheses around arithmetic in operand of '|' [-Wparentheses]
commandW7(TicCommand::SetAgcOption, 0x20 | (uint8_t)steps & 0xF);
C:\Users\GEORGE\Documents\Arduino\libraries\Tic/Tic.h: In member function 'void TicBase::setAgcFrequencyLimit(TicAgcFrequencyLimit)':
C:\Users\GEORGE\Documents\Arduino\libraries\Tic/Tic.h:708:63: warning: suggest parentheses around arithmetic in operand of '|' [-Wparentheses]
commandW7(TicCommand::SetAgcOption, 0x30 | (uint8_t)limit & 0xF);
In file included from C:\Users\GEORGE\Documents\Arduino\libraries\Tic\Tic.cpp:1:0:
C:\Users\GEORGE\Documents\Arduino\libraries\Tic\Tic.cpp: In member function 'virtual void TicI2C::commandW32(TicCommand, uint32_t)':
C:\Users\GEORGE\Documents\Arduino\libraries\Tic\Tic.cpp:190:22: error: call of overloaded 'write(uint32_t)' is ambiguous
Wire.write(val >> 0); // lowest byte
In file included from C:\Users\GEORGE\Documents\Arduino\libraries\Tic/Tic.h:15:0,
C:\Users\GEORGE\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\2.2.0\libraries\Wire/Wire.h:59:20: note: candidate: virtual size_t arduino::MbedI2C::write(uint8_t)
virtual size_t write(uint8_t data);
C:\Users\GEORGE\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\2.2.0\libraries\Wire/Wire.h:60:20: note: candidate: virtual size_t arduino::MbedI2C::write(int)
virtual size_t write(int data) {
C:\Users\GEORGE\Documents\Arduino\libraries\Tic\Tic.cpp:191:22: error: call of overloaded 'write(uint32_t)' is ambiguous
Wire.write(val >> 8);
C:\Users\GEORGE\Documents\Arduino\libraries\Tic\Tic.cpp:192:23: error: call of overloaded 'write(uint32_t)' is ambiguous
Wire.write(val >> 16);
C:\Users\GEORGE\Documents\Arduino\libraries\Tic\Tic.cpp:193:23: error: call of overloaded 'write(uint32_t)' is ambiguous
Wire.write(val >> 24); // highest byte
exit status 1
Error compiling for board Arduino Nano 33 BLE.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Not sure if I am doing something wrong ot just the library does not work on Arduino Nano 33 BLE.
Thanks!
