I have soldered the capacitor that came with the 24v23 and soldered the 3 headers in order to use RC down the road. I have also soldered 14 gauge wire to the VIN connections and to the motor outputs.
My question is should I be able to connect my 12v motor and use a 12 volt battery charger as the power source or are the standard cables on the charger too long to drive the motor when I connect the 24v 23 to my laptop via USB? EDIT: The charger is a standard 6/12 v charger that would be used to charge a car battery.
Thanks for any help anyone is able to provide.
Mike
