it say that this can handle 1.2A per channel, if i have 2 dc motors with stall current of 1.1A each would the TB6612FNG handle the motors without cutting out or burning?
thanks
thanks
It sounds like you might be referring to our TB6612FNG Dual Motor Driver Carrier. If so, it can handle 1A continuously with peaks of up to 3A. Those motors will likely be fine with that driver as long as you are not operating it close to stall for any extended period.
-Derrill
