Hi everyone !
I am facing problem in driving two 50 rpm dc motors using arduino uno and TB6612FNG Dual Motor Driver.
can anyone provide me with a test circuit with pin connections and arduino code to do a test whether the driver is working or not .!!
I have tried a few codes but none of them were able to drive the motors.
I don’t know whether the problem is in the code or in the driver connections…
Plz help ASAP
I am sorry you are having problems with your motor driver. For testing each channel, you will need to control STBY, PWM and both IN pins. For more information about these connections, you can refer to the truth table on page 4 in the TB6612FNG datasheet. We do not have any demo code for use with the TB6612FNG carrier, but if you post your code, I would be happy to take a look at it and give pointers. Pictures of your setup would also be helpful.
- Jeremy
