STL_REP pull-up on DRV8434A boards
Hi!
I want to use stall detection on your TI DRV8434A board. However, from your schematic in Pololu - DRV8434A Stepper Motor Driver Carrier there is no built-in pull-up resistor for the STL_REP pin. Does that mean I have to add a pin header to my board just to add the pull-up required to enable nFAULT stall reporting?
The DRV8434A datasheet states that (table “7-6. Stall Detection Operating Mode”)
If STL_REP > 1.6V, nFAULT goes low when stall is detected
and that (in section “7.3.8.1 nFAULT Pin”)
The STL_REP pin has open-drain output and must be pulled up to a 5 V, 3.3 V or 1.8 V supply
Thanks!
As you mentioned, you need to pull the STL_REP pin high to enable fault detection. Is there a reason you do not want to solder a header pin to it? Alternatively, you could just solder the pull-up resistor directly to it.
I was confused because the STL_REP pin is not soldered in you pre-soldered headers variant, and is not included in your headers included variant (I count 16 pins in the product photo).
Ideally, the STL_REP pin should be pulled up by default, so the 2x8 side row pins were enough for using stall detection.
The board has a spot for an STL_REP pull up resistor to 5V VDD that we can add as a customization, but we don’t populate it by default because it could limit that board’s use in 3.3V systems.
