// This example shows how to send serial commands to the Tic
// Stepper Motor Controller to control the speed of a Stepper
// Motor.
// The Tic's control mode must be set to "Serial/I2C/USB". The
// baud rate should be set to 9600 and CRC should not be enabled.
// This example uses the Compact Protocol, so the Tic's device
// number is not used, and can be set to anything.
// If you have sent a De-energize command to the Tic, for example
// by clicking "De-energize" in the Tic Control Center, you will
// need to undo that by clicking "Resume" or power-cycling the
// Tic.
// Please see https://github.com/pololu/tic-arduino for details
// on how to make the connections between the Arduino and the
// Tic.
#include <Tic.h>
// On boards with a hardware serial port available for use, use
// that port to communicate with the Tic. For other boards,
// create a SoftwareSerial object using pin 10 to receive (RX)
// and pin 11 to transmit (TX).
#ifdef SERIAL_PORT_HARDWARE_OPEN
#define ticSerial SERIAL_PORT_HARDWARE_OPEN
#else
#include <SoftwareSerial.h>
SoftwareSerial ticSerial(10, 11);
#endif
TicSerial tic(ticSerial);
void setup()
// Set the baud rate.
ticSerial.begin(9600);
// Give the Tic some time to start up.
delay(20);
// Add this line for debugging
Serial.begin(9600);
// Tells the Tic that it is OK to start driving the motor. The
// Tic's safe-start feature helps avoid unexpected, accidental
// movement of the motor: if an error happens, the Tic will not
// drive the motor again until it receives the Exit Safe Start
// command. The safe-start feature can be disbled in the Tic
// Control Center.
tic.exitSafeStart();
// Sends a "Reset command timeout" command to the Tic. We must
// call this at least once per second, or else a command timeout
// error will happen. The Tic's default command timeout period
// is 1000 ms, but it can be changed or disabled in the Tic
// Control Center.
void resetCommandTimeout()
tic.resetCommandTimeout();
// Delays for the specified number of milliseconds while
// resetting the Tic's command timeout so that its movement does
// not get interrupted.
void delayWhileResettingCommandTimeout(uint32_t ms)
uint32_t start = millis();
do
} while ((uint32_t)(millis() - start) <= ms);
void loop()
// Move forward at 200 steps per second for 2 seconds.
tic.setTargetVelocity(2000000);
delayWhileResettingCommandTimeout(2000);
// Decelerate to a stop.
tic.setTargetVelocity(0);
delayWhileResettingCommandTimeout(1000);
// Move in reverse at 100 steps per second for 1 second.
tic.setTargetVelocity(-1000000);
Serial.println("Moving forward...");
Serial.println("Decelerating...");
// Add similar debug statements for other movements...
Serial.println("Done.");
Thank you for posting your code on the forum. I noticed that nothing in the code you posted matches the errors you were getting in your email; are you still getting errors or is the stepper motor just not responding? Could you post some pictures of your setup that show all of your connections as well as a copy of your Tic settings file? You can save a copy of your Tic settings file from the “File” drop-down menu in the Tic Control Center software while the controller is connected.
By the way, I tried compiling your code and had to change your quotation marks to ASCII quotations (") instead of unicode (”) to get it to compile successfully.
