Our aim is not only drive straight line also I can publish our arduino code. My motors have encoders and I applied PID however motors are not still same speed. I was able to equalize their speed in no-load state, but their speed changes when the load is loaded and the PID doesn’t work
#include <Wire.h>
#include <PID_v1.h>
#include <ros.h>
#include <std_msgs/String.h>
#include <geometry_msgs/Vector3Stamped.h>
#include <geometry_msgs/Twist.h>
#include <geometry_msgs/Pose2D.h>
#include <ros/time.h>
#include <ArduinoHardware.h>
#include <std_msgs/Float64.h>
//initializing all the variables
#define LOOPTIME 100 //Looptime in millisecond
const byte noCommLoopMax = 10; //number of main loops the robot will execute without communication before stopping
unsigned int noCommLoops = 0; //main loop without communication counter
const int PIN_L_IN1 = 24;
const int PIN_L_IN2 = 25;
const int PIN_L_PWM = 6;
const int PIN_L_ENCOD_A_MOTOR = 2; //A channel for encoder of left motor
const int PIN_L_ENCOD_B_MOTOR = 4; //B channel for encoder of left motor
const int PIN_R_IN1 = 30;
const int PIN_R_IN2 = 31;
const int PIN_R_PWM = 7;
const int PIN_R_ENCOD_A_MOTOR = 3; //A channel for encoder of right motor
const int PIN_R_ENCOD_B_MOTOR = 18; //B channel for encoder of right motor
unsigned long lastMilli = 0;
const double radius = 0.07; //Wheel radius, in m
const double wheelbase = 0.325; //Wheelbase, in m
double speed_req = 0; //Desired linear speed for the robot, in m/s
double angular_speed_req = 0; //Desired angular speed for the robot, in rad/s
double speed_req_left = 0; //Desired speed for left wheel in m/s
double speed_act_left = 0; //Actual speed for left wheel in m/s
double speed_cmd_left = 0; //Command speed for left wheel in m/s
double speed_req_right = 0; //Desired speed for right wheel in m/s
double speed_act_right = 0; //Actual speed for right wheel in m/s
double speed_cmd_right = 0; //Command speed for right wheel in m/s
const double max_speed = 0.4; //Max speed in m/s
int PWM_leftMotor = 0; //PWM command for left motor
int PWM_rightMotor = 0; //PWM command for right motor
unsigned int encoder_left = 0;
unsigned int encoder_right = 0;
// PID Parameters
const double PID_left_param[] = { 0.29, 0, 0.0 }; //Respectively Kp, Ki and Kd for left motor PID
const double PID_right_param[] = { 0.262, 0, 0.0 }; //Respectively Kp, Ki and Kd for right motor PID
volatile float pos_left = 0; //Left motor encoder position
volatile float pos_right = 0; //Right motor encoder position
PID PID_leftMotor(&speed_act_left, &speed_cmd_left, &speed_req_left, PID_left_param[0], PID_left_param[1], PID_left_param[2], DIRECT); //Setting up the PID for left motor
PID PID_rightMotor(&speed_act_right, &speed_cmd_right, &speed_req_right, PID_right_param[0], PID_right_param[1], PID_right_param[2], DIRECT); //Setting up the PID for right motor
ros::NodeHandle nh;
//function that will be called when receiving command from host
void handle_cmd (const geometry_msgs::Twist& cmd_vel) {
noCommLoops = 0; //Reset the counter for number of main loops without communication
speed_req = cmd_vel.linear.x; //Extract the commanded linear speed from the message
angular_speed_req = cmd_vel.angular.z; //Extract the commanded angular speed from the message
speed_req_left = speed_req - angular_speed_req * (wheelbase / 2); //Calculate the required speed for the left motor to comply with commanded linear and angular speeds
speed_req_right = speed_req + angular_speed_req * (wheelbase / 2); //Calculate the required speed for the right motor to comply with commanded linear and angular speeds
geometry_msgs::Pose2D pwm_output_msg;
geometry_msgs::Pose2D encoder_msg;
geometry_msgs::Vector3Stamped speed_msg; //create a "speed_msg" ROS message
ros::Subscriber<geometry_msgs::Twist> cmd_vel("cmd_vel", handle_cmd); //create a subscriber to ROS topic for velocity commands (will execute "handle_cmd" function when receiving data)
ros::Publisher speed_pub("speed", &speed_msg); //create a publisher to ROS topic "speed" using the "speed_msg" type
ros::Publisher pwm_output_pub("pwm_output", &pwm_output_msg);
ros::Publisher encoder_pub("encoder", &encoder_msg);
void setup() {
nh.initNode(); //init ROS node
nh.getHardware()->setBaud(57600); //set baud for ROS serial communication
nh.subscribe(cmd_vel); //suscribe to ROS topic for velocity commands
nh.advertise(speed_pub); //prepare to publish speed in ROS topic
nh.advertise(encoder_pub);
nh.advertise(pwm_output_pub);
//setting motor speeds to zero
pinMode(PIN_L_IN1, OUTPUT);
pinMode(PIN_L_IN2, OUTPUT);
pinMode(PIN_L_PWM, OUTPUT);
pinMode(PIN_R_IN1, OUTPUT);
pinMode(PIN_R_IN2, OUTPUT);
pinMode(PIN_R_PWM, OUTPUT);
//setting PID parameters
PID_leftMotor.SetSampleTime(95);
PID_rightMotor.SetSampleTime(95);
PID_leftMotor.SetOutputLimits(-max_speed, max_speed);
PID_rightMotor.SetOutputLimits(-max_speed, max_speed);
PID_leftMotor.SetMode(AUTOMATIC);
PID_rightMotor.SetMode(AUTOMATIC);
// Define the rotary encoder for left motor
pinMode(PIN_L_ENCOD_A_MOTOR, INPUT);
pinMode(PIN_L_ENCOD_B_MOTOR, INPUT);
digitalWrite(PIN_L_ENCOD_A_MOTOR, HIGH); // turn on pullup resistor
digitalWrite(PIN_L_ENCOD_B_MOTOR, HIGH);
attachInterrupt(0, encoderLeftMotor, RISING);
// Define the rotary encoder for right motor
pinMode(PIN_R_ENCOD_A_MOTOR, INPUT);
pinMode(PIN_R_ENCOD_B_MOTOR, INPUT);
digitalWrite(PIN_R_ENCOD_A_MOTOR, HIGH); // turn on pullup resistor
digitalWrite(PIN_R_ENCOD_B_MOTOR, HIGH);
attachInterrupt(digitalPinToInterrupt(PIN_R_ENCOD_A_MOTOR), encoderRightMotor, RISING);
void loop() {
nh.spinOnce();
if ((millis() - lastMilli) >= LOOPTIME)
lastMilli = millis();
if (abs(pos_left) < 5) { //Avoid taking in account small disturbances
speed_act_left = 0;
else {
speed_act_left = ((pos_left / 480) * 2 * PI) * (1000 / LOOPTIME) * radius; // calculate speed of left wheel !!!! 990 encoder total pulse coun
if (abs(pos_right) < 5) { //Avoid taking in account small disturbances
else {
speed_act_right = ((pos_right / 480) * 2 * PI) * (1000 / LOOPTIME) * radius; // calculate speed of right wheel !!!! 990 encoder total pulse coun
encoder_left = encoder_left + pos_left;
encoder_right = encoder_right + pos_right;
if(encoder_left>32000) encoder_left = 0;
if(encoder_right>32000) encoder_right = 0;
pos_left = 0;
pos_right = 0;
speed_cmd_left = constrain(speed_cmd_left, -max_speed, max_speed);
PID_leftMotor.Compute(); // compute PWM value for left motor
PWM_leftMotor = constrain(((speed_req_left+sgn(speed_req_left)*0.0882)/0.00235) + (speed_cmd_left/0.00235), -255, 255);
if (noCommLoops >= noCommLoopMax) { //Stopping if too much time without command
analogWrite(PIN_L_PWM, 0);
else if (speed_req_left == 0) { //Stopping
else if (PWM_leftMotor > 0) { //Going forward
analogWrite(PIN_L_PWM, PWM_leftMotor);
digitalWrite(PIN_L_IN1, HIGH);
digitalWrite(PIN_L_IN2, LOW);
else { //Going backward
analogWrite(PIN_L_PWM, abs(PWM_leftMotor));
digitalWrite(PIN_L_IN1, LOW);
digitalWrite(PIN_L_IN2, HIGH);
speed_cmd_right = constrain(speed_cmd_right, -max_speed, max_speed);
PID_rightMotor.Compute(); // compute PWM value for right motor
PWM_rightMotor = constrain(((speed_req_right+sgn(speed_req_right)*0.0882)/0.00235) + (speed_cmd_right/0.00235), -255, 255);
analogWrite(PIN_R_PWM, 0);
else if (speed_req_right == 0) { //Stopping
else if (PWM_rightMotor > 0) { //Going forward
analogWrite(PIN_R_PWM, PWM_rightMotor);
digitalWrite(PIN_R_IN1, HIGH);
digitalWrite(PIN_R_IN2, LOW);
analogWrite(PIN_R_PWM, abs(PWM_rightMotor));
digitalWrite(PIN_R_IN1, LOW);
digitalWrite(PIN_R_IN2, HIGH);
noCommLoops++;
if (noCommLoops == 65535) {
noCommLoops = noCommLoopMax;
publishSpeed(); //Publish odometry on ROS topic
//Publish function for odometry, uses a vector type message to send the data (message type is not meant for that but that's easier than creating a specific message type)
void publishSpeed() {
speed_msg.header.stamp = nh.now(); //timestamp for odometry data
speed_msg.vector.x = speed_act_left; //left wheel speed (in m/s)
speed_msg.vector.y = speed_act_right; //right wheel speed (in m/s)
speed_msg.vector.z = LOOPTIME / 1000; //looptime, should be the same as specified in LOOPTIME (in s)
speed_pub.publish(&speed_msg);
encoder_msg.x= encoder_left;
encoder_msg.y= encoder_right;
encoder_pub.publish( &encoder_msg);
pwm_output_msg.x = PWM_leftMotor;
pwm_output_msg.y = PWM_rightMotor;
pwm_output_pub.publish(&pwm_output_msg);
nh.spinOnce();
nh.loginfo("Publishing odometry");
//Left motor encoder counter
void encoderLeftMotor() {
if (digitalRead(PIN_L_ENCOD_A_MOTOR) == digitalRead(PIN_L_ENCOD_B_MOTOR)) pos_left++;
else pos_left--;
//Right motor encoder counter
void encoderRightMotor() {
if (digitalRead(PIN_R_ENCOD_A_MOTOR) == digitalRead(PIN_R_ENCOD_B_MOTOR)) pos_right--;
else pos_right++;
template <typename T> int sgn(T val) {
return (T(0) < val) - (val < T(0));
