Hello
What I aim to do: Would like the 3pi+ to travel at a desirable speed to cover a straight path of 1 meters.
I have implemented a PID control loop for each motor as shown in the code below. I have tuned the PID weights for a heading velocity of 25 cm/s.
I was monitoring the encoder counts to verify if each wheel has travelled 1 meters at the end of the experiment. Based on the CPR (Counts Per Revolution) for these motors, I calculated the encoder counts, corresponding to 1 meter, to be 3561 counts (approximately).
So my thought process is that for the tuned PID gains at a desirable robot speed the encoder counts for each motor should be 3561 since the distance remains the same for all the experiments.
But what I noticed is different, for a desirable speed of 30 cm/s the robot travelled an additional 5.6cm that is 3860 counts.
I was hoping to understand why this is the case and any suggestions on this would be deeply appreciated. Attaching the code below.
This program is intended to tune the PIDs for each of the wheel of the 3pi+ robots
#include <Pololu3piPlus32U4.h>
#define distance 1.0 // distance travelled in meters
#define desired_speed 0.25 // in m/s
#define top_speed 1.5 // in m/s
#define CPR 358 // counts per revolution
#define wheel_diameter 0.032 // wheel diameter in meters
#define time_sampl 1 // in milliseconds
using namespace Pololu3piPlus32U4;
LCD display;
Motors motors;
Encoders encoders;
// Left Wheel
#define P_l 0.395
#define I_l 0.001
#define D_l 0.0
// Right Wheel
#define P_r 0.365
#define I_r 0.0
#define D_r 0.0
// to store previous errors
float prev_err_l = 0;
float prev_err_r = 0;
// storing integral errors
int16_t int_err_vel_l = 0;
int16_t int_err_vel_r = 0;
// time variables
int start_time = 0;
float prev_time = 0.0;
// storing total number of encoder counts the robot has travelled
uint16_t total_enc_l = 0;
uint16_t total_enc_r = 0;
uint8_t k = 1;
int32_t int_error;
void setup() {
// put your setup code here, to run once:
display.clear();
delay(1000);
void loop() {
// put your main code here, to run repeatedly:
if (start_time == 0)
start_time = millis();
float curr_time = (millis() - start_time) / 1000.0;
// when time elapsed is more than the required time to travel 1.0 meters; stop program
if (curr_time > distance / desired_speed)
// displaying encoder counts on the LCD
display.clear(); display.print(total_enc_l);
display.gotoXY(0, 1); display.print(total_enc_r);
motors.setSpeeds(0, 0);
delay(100000); //100 second delay
return;
if (millis() >= (prev_time * 1000 + time_sampl)) {
int16_t curr_enc_l = encoders.getCountsAndResetLeft();
int16_t curr_enc_r = encoders.getCountsAndResetRight();
// intergral anti-windup
if (int_err_vel_l > 1000)
int_err_vel_l = 0;
if (int_err_vel_r > 1000)
int_err_vel_r = 0;
// error calculations
float err_vel_l = desired_speed - ((curr_enc_l * 0.1 / CPR) * 3.14 * wheel_diameter) / (curr_time - prev_time);
float err_vel_r = desired_speed - ((curr_enc_r * 0.1 / CPR) * 3.14 * wheel_diameter) / (curr_time - prev_time);
// differential error calculations
int16_t diff_vel_l = (err_vel_l - prev_err_l) / (curr_time - prev_time);
int16_t diff_vel_r = (err_vel_r - prev_err_r) / (curr_time - prev_time);
// updating integral error summation
int_err_vel_l += err_vel_l;
int_err_vel_r += err_vel_r;
// control wheel velocity calculations
float ul = (float)(1.0 * desired_speed + (P_l * (err_vel_l) + I_l * (int_err_vel_l) + D_l * (diff_vel_l)));
float ur = (float)(1.0 * desired_speed + (P_r * (err_vel_r) + I_r * (int_err_vel_r) + D_r * (diff_vel_r)));
uint32_t cmd_l = (uint32_t)((ul*60.0) / (PI * wheel_diameter)); // in RPM
uint32_t cmd_r = (uint32_t)((ur*60.0) / (PI * wheel_diameter)); // in RPM
// sending control motor commands to motors
motors.setSpeeds(cmd_l, cmd_r);
// recording current state data for next iteration
prev_err_l = err_vel_l;
prev_err_r = err_vel_r;
prev_time = curr_time;
total_enc_l += curr_enc_l;
total_enc_r += curr_enc_r;
Thanks
Update: I found an unusual observation today. Two days ago, I had tuned the PID gains for each of the motors for 25 cm/s with a steady state error of about 1cm. Today, when running the same experiment with no changes to the code I see a steady state error to be around 5cm. Requiring me to retune the PID gains.
I am having the robot run on a flex sheet, so naturally I expect some drift. But this is outright strange. Maybe I will have to see if it occurs again in the future.
