SMC G2 18v25 CAN bus
I pulled out the magnify glass an noticed the micro driving this board is a STMF103T8U6 (Arm cortex M3). I pulled the data sheet and found it supports CAN2.0. Is there a way to get the CAN rx/tx muxed to either the TX, RX/SDA or SCL pads IO? An external CAN transceiver could be added to connect to a bus. Keep the same serial format but have a formatted header ID for sending data and a separate for receiving.
In theory one could have several SMC G2 tied to the bus and all controlled over CAN.
Ryan
Hello, Ryan.
Unfortunately, it looks like the CAN pins are used for USB, so adding a CAN interface to the G2 Simple Motor Controllers would require a non-trivial redesign that would cost at least several thousand dollars. If you are interested in a customized version and would like to pursue this further, please email us with your target quantities and schedule.
Unfortunately I only need a single unit. In general having a DC motor controller that has CAN would be pretty nice.
