I need to start from center position and then turn my servo from center position to turn left when switch 1 on closed. Then when switch 1 is open, back to middle. When switch 2 is closed, turn right, and again when switch 2 is open, in to the middle. Switches will not operate at the same time. This is a project to my boat setting gear to forward - idle - reverse, instead of mechanical lever and add remote control too.
Probably the easiest way to do something like that would be two IF/ELSE statements chained together. For example, the first one could check switch one and move the servo to the left if it is closed:
1 get_position 500 less_than if
#move servo to left
If switch one is open, check switch 2, and move the servo to the right if it is closed:
else 2 get_position 500 less_than if
# move servo to right
If switch 2 is open, that means that both switches are open, so you can set the servo to the center:
