Greetings,
I have spent many hours looking over your script examples and searching your forum for what i think is a simple task.
I am using a relay switch and your micro maestro 6 to actuate 2 servos. I have been able to move the servos to a new position with each closed switch command. What I would like to have happen is for the servos to move to a position when closed and return when open. The following is a script example I am attempting to edit for my purpose.
Thank you in advance for the help.
Regards, Harold
# Uses WAIT_FOR_BUTTON_PRESS to allow a user to step through a sequence
# of positions on servo 4,5
begin
wait_for_button_press
8000 4 servo
500 delay
8000 5 servo
500 delay
Wait_for_button_press
500 4 servo
500 delay
500 5 servo
500 delay
repeat
# Returns 1 if the button is pressed, 0 otherwise.
sub button
0 get_position 500 less_than
return
# Waits for a button press, with debouncing.
# (Requires the BUTTON subroutine.)
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
# wait for the button to be NOT pressed for at least 10 ms
sub wait_for_button_open_10ms
get_ms # put the current time on the stack
begin
# reset the time on the stack if it is pressed
button
if
drop get_ms
else
if drop return endif
endif
repeat
# wait for the button to be pressed for at least 10 ms
sub wait_for_button_closed_10ms
get_ms
begin
button
if
else
drop get_ms
endif
repeat
