Hi
I am trying to run two motors using an arduino mega and pololu simple motor controller. I am stuck and need assistance. I was able to use one motor but now i want to control individual motors. I am not an expert on this and could use some help. I tried using the example code and tweaking it but i cant get it to work :’( please help ASAP
#include <SoftwareSerial.h>
#define rxPin 0 // pin 0 connects to smcSerial TX (not used in this example)
#define txPin 1 // pin 1 connects to smcSerial RX
SoftwareSerial smcSerial = SoftwareSerial(rxPin, txPin);
// required to allow motors to move
// must be called when controller restarts and after any error
void exitSafeStart()
smcSerial.write(0x83);
// speed should be a number from -3200 to 3200
void setMotorSpeed(int speed, unsigned char deviceId)
Serial.write(0xAA); // first byte of Pololu protocol
Serial.write(deviceId); // determine which controller gets the command
if (speed < 0)
Serial.write(0x06); // Pololu protocol version of motor reverse command
speed = -speed; // make speed positive
else
Serial.write(0x05); // Pololu protocol version of motor forward command
Serial.write((unsigned char)(speed & 0x1F));
Serial.write((unsigned char)(speed >> 5));
void setup()
// initialize software serial object with baud rate of 19.2 kbps
smcSerial.begin(19200);
// the Simple Motor Controller must be running for at least 1 ms
// before we try to send serial data, so we delay here for 5 ms
delay(5);
// if the Simple Motor Controller has automatic baud detection
// enabled, we first need to send it the byte 0xAA (170 in decimal)
// so that it can learn the baud rate
smcSerial.write(0xAA); // send baud-indicator byte
// next we need to send the Exit Safe Start command, which
// clears the safe-start violation and lets the motor run
exitSafeStart(); // clear the safe-start violation and let the motor run
void loop()
setMotorSpeed(3200, 0xb); // full-speed forward for controller 0xb
setMotorSpeed(3200, 0xd); // full-speed forward for controller 0xd
delay(20000); // wait for 2 seconds
setMotorSpeed(-3200, 0xb); // full-speed reverse for controller 0xb
setMotorSpeed(-3200, 0xd); // full-speed reverse for controller 0xd
