Hello!
I apologize in advance if this question sounds stupid. I am very VERY new to electronics/robotics and need to buy a 12V motor with an encoder for a project I am working on.
This is the current list I am choosing from:
Since the High-Power options are in the $50 range this is quite an expensive purchase for me and I want to clarify some things before I make a purchase.
For example, this “20.4:1 Metal Gearmotor 25Dx65L mm HP 12V with 48 CPR Encoder” (Pololu - 20.4:1 Metal Gearmotor 25Dx65L mm HP 12V with 48 CPR Encoder) is listed as having 500 rpm (no-load) but a 20.4:1 gear ratio. Does that mean the output shaft (the metal thing that will actually spin on the outside and turn things) is going to spin at 500x20.4=10,200 rpm?
The goal of the motor is to power an electric toy car (weighing 0.86 kg or 1.9 lbs) that will go very fast for ~8-10 meters and then stop fast as well. The motor is directly connected to a gear that spins the axle, so that is why I am trying to figure out the output rpm. My current motor completed an 8-meter track in 8.5 seconds, but I want to lower this time. I presume I want to increase torque to have more acceleration because it is such a short distance and time? Would this also mean I should pick a motor with a higher gear ratio (ex. 20.4:1 instead of 4.4:1)?
Thank you so much for any input!
- Emerson
