Hi. I have a problem with my RoboClaw. I use RC mode to control the motors with the flight controller. But it only works when I connect RoboClaw to my PC via USB and start Motion Studio. After that, if I disconnect the USB, it still works. No errors in Motion studio.
Please help me solve this problem.
Best regards
After you configure the RoboClaw settings appropriately in the Motion Studio software, are you clicking the āWrite Settingsā option in the āDeviceā drop-down menu to save them to the controller before disconnecting it?
Hello. Yes, more than once. I am a technical engineer, the settings have been checked and recorded. I suspect that the driverās non-volatile memory is damaged. When I first connected it to the PC, the program asked to update the firmware to 1.4, I updated the firmware. After that, I connected the driver to another PC, and on the other PC the program again asked to update the firmware to the same version. I will try to put the driver into bootloader mode, if possible, and update the firmware again.
Ok. I found a solution. This is bug in latest firmware. I install legacy version of software and downgrade firmware of my roboclaw. Thatās halp. Now settings are writing and after reboot driver all works fineāŗļø
I am glad to hear you got it working! Thank you for letting us know how you fixed it.
Good luck on your project!
