Hey all! I was referred to come here from Adafruit. Apologies if this is a question that is easily answered, I did some searching but hadn’t found a good answer yet.
So I’m wanting to breathe new life into this old x,y microscope stage similar to this: https://www.ebay.com/itm/Microscope-stage-with-x-y-motors-no-controller/132473152790.
According to the specs of the motors found here: http://www.probyte.fi/pdf/mae2220.pdf (page 10) the motor type is HY 200-2215-150 B 8. According to the spec sheet, the phase resistance is 1.5 ohms per coil. They’re rated at 1.5A and a max voltage of 75V. These motors won’t have to work very fast at all (doing microscopic photography), so I’m hoping I can run at a lower voltage as the torque required should be low, just to move those two plates around.
What would be a good stepper motor controller to match those beasty motors? Ideally would be using a Pi or Arduino Uno setup similar to the Adafruit Motor Shield V2, although my main goal is to just get the motors to move via computer control so if there’s a better way to do it other than Pi or Arduino I’m totally open to that. Any suggestions?
Thanks everyone for your help, trying to do as much research as I can, apologies if I missed something obvious. Thank you!
