Thank you for your a quick reply!
I see now that I didn’t give you enough information, I wrote this in a hurry.
The library I am using is the Pololu Reflection PololuQTRSensors.h.
I thought I was updating the sensor values by defining sensor6 in the end of the while loop to help him update his values.
unsigned int sensor_6 = (sensorValues[6] * 10 / 1001);
It looks like it doesn’t work.
Here’s the whole code:
#include <PololuQTRSensors.h>
//mótorar
#define PWMA 10
#define AIN1 2
#define AIN2 3
#define BIN1 7
#define BIN2 5
#define PWMB 11
//flagg
#define CIN1 42
#define CIN2 40
#define PWMC 8
#define STBY 38
#define VCC_flagg 34
//breytur
#define motor_C 1
#define motor_A 0
#define motor_B 1
#define FORWARD 1
#define REVERSE 0
#define RIGHT 1
#define LEFT 0
//takkar
#define BUTTON_4 27
int buttonState4 = 0;
#define NUM_SENSORS 6 // number of sensors used
#define TIMEOUT 2500 // waits for 2500 us for sensor outputs to go low
#define EMITTER_PIN 35 // emitter is controlled by digital pin 2
#define VCC_skynjari 45
PololuQTRSensorsRC qtrrc((unsigned char[]) {41, 43, 37, 39, 46, 48},
NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
int DOT = 0;
volatile int sensor_1=0;
volatile int sensor_6=0;
void setup()
pinMode(CIN1,OUTPUT);
pinMode(CIN2,OUTPUT);
pinMode(PWMC,OUTPUT);
pinMode(STBY,OUTPUT);
pinMode(PWMA,OUTPUT);
pinMode(AIN1,OUTPUT);
pinMode(AIN2,OUTPUT);
pinMode(PWMB,OUTPUT);
pinMode(BIN1,OUTPUT);
pinMode(BIN2,OUTPUT);
pinMode(VCC_skynjari,OUTPUT);
pinMode(VCC_flagg,OUTPUT);
//BUTTON
pinMode(BUTTON_4,INPUT);
digitalWrite(VCC_skynjari,HIGH);
digitalWrite(VCC_flagg,HIGH);
digitalWrite(STBY,HIGH);
Serial.begin(9600);
void calibration()
motor_bremsahratt();
delay(1000);
halda_flaggi();
delay(1000);
void loop()
buttonState4 = digitalRead(BUTTON_4);
motor_fastbrake();
if (buttonState4 == HIGH) {
DOT = 1;
while (DOT =1)
motor_control(motor_A,FORWARD,50);
motor_control(motor_B,FORWARD,50);
unsigned int sensor_1 = (sensorValues[1] * 10 / 1001);
printvalues();
if (sensor_6 >= 5)
printvalues();
while sensor_1 < 5)
printvalues();
brake_A();
motor_control(motor_A,FORWARD,50); //the plan here is that when the robot is perpendicular to the line
motor_control(motor_B,FORWARD,50); //it drives forward for 1 second and brakes.
delay(1000);
motor_fastbrake();
delay(1000000);
//------ below are functions for motors and the printvalue funtion-------//
void motor_control(char motor, char direction, unsigned char speed)
if (motor == motor_A)
if (direction == FORWARD)
digitalWrite(AIN1,HIGH);
digitalWrite(AIN2,LOW);
else
digitalWrite(AIN1,LOW);
digitalWrite(AIN2,HIGH);
analogWrite(PWMA,speed);
else
if (direction == REVERSE) //Notice how the direction is reversed for motor_B
{ //This is because they are placed on opposite sides so
digitalWrite(BIN1,LOW); //to go FORWARD, motor_A spins CW and motor_B spins CCW
digitalWrite(BIN2,HIGH);
else
digitalWrite(BIN1,HIGH);
digitalWrite(BIN2,LOW);
analogWrite(PWMB,speed);
void brake_A()
digitalWrite(AIN1,1);
digitalWrite(AIN2,1);
digitalWrite(PWMA,HIGH);
void brake_B()
digitalWrite(BIN1,1);
digitalWrite(BIN2,1);
digitalWrite(PWMB,HIGH);
void motor_fastbrake()
void motor_slowbrake()
digitalWrite(PWMA,LOW);
digitalWrite(PWMB,LOW);
void calibration()
int i;
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
for (i = 0; i < 400; i++) // make the calibration take about 10 seconds
qtrrc.calibrate(); // reads all sensors 10 times at 2500 us per read (i.e. ~25 ms per call)
digitalWrite(13, LOW);
// print the calibration minimum values measured when emitters were on
for (i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn[i]);
Serial.print(' ');
Serial.println();
// print the calibration maximum values measured when emitters were on
Serial.print(qtrrc.calibratedMaximumOn[i]);
Serial.print(' ');
Serial.println();
Serial.println();
void printvalues()
int position = qtrrc.readLine(sensorValues);
volatile int skynjari_1 = (sensorValues[1] * 10 / 1001);
volatile int skynjari_6 = (sensorValues[6] * 10 / 1001);
//qtrrc.read(sensorValues);
// print the sensor values as numbers from 0 to 9, where 0 means maximum reflectance and
// 9 means minimum reflectance, followed by the line position
unsigned char i;
Serial.print(sensorValues[i] * 10 / 1001);
Serial.print(' ');
Serial.print(" ");
Serial.println(position);
Some of the definitions are in Icelandic but most of it is in English.
Iv’e read something about volatile, is that something that could help me?
regards, steinidna.
