I was wondering if anyone could explain some of the arduino library parameters in more detail.
I’ve read through the readme and I am currently using the driver to run the motor fine - As in I can start/stop/increase i to increase “speed”. However, I’d like to know more about the speed parameter and what the i = 400 in the demo refers to in terms of actual value being changed on the microcontroller.
For instance, I’m used to PWM where setting 255 would be 100% duty cycle and etc. What would be the equivalent of duty cycle control if I were to implement it with this driver?
I’m controlling a relatively high power (1HP) DC brushed motor at 24V, and would like to soft start with a lower voltage to avoid a large surge current. After that, I’d like to increase the duty cycle to around 75% to reach peak operating efficiency (as per the datasheet recommendation). If anyone can give me some pointers that would be lovely!
Edit: After reading function definitions, I notice a peculiar problem. When my speed is set to 400 (255 PWM), the motor operates extremely slowly under a full load.
However, when I increase this 400 to a much higher value, the motor responds by running much faster (even though the code sets speed to 400 if a higher value is passed in). What exactly is happening and why is the motor running faster when I pass in a value much greater than 400?
