Hey @all!
I’ve got some question about the Qik 2s12v10 as I couldn’t find an answer in the manual.
I have connected a motor (e.g. 12 V) to the board. Normally I use the board to drive the motor through pwm.
But what happens if the connected motor is driven externally? Imagine there is a fly wheel that could be rotaded manually for example. Then the motor acts as a generator. In my case I noticed that then the motor indicator led lights on, further the blue power led.
Now my questions:
- Is that a normal behavior of the board?
- Could the board be damaged through such a setup?
- Do I have to provide a protection against the voltage generated through the externally driven motor?
Thanks in advance for your answers!
