I have a 12vdc small water pump, the pressure is too high for my application, I was thinking if I can use a 18v15 motor controller and use the speed -3200 to 3200 to regulate its pressure? would this work?
Hello, starguy.
If the pump’s electrical input is directly connected to a brushed DC motor that does not draw more than 15 amps it might work. I do not know how likely that is to be the case with your pump.
- Ryan
Its about 3A @12VDC however I believe its brushless, would this not work?
Unfortunately, probably not. We don’t sell any drivers or controllers that work with brushless motors at this time.
- Ryan
