im gonna preface by saying im pretty new to electronics, and im sorry for the yap
I have an Arduino Uno, which I want to use to control 4 37D 12 volt Metal Gearmotors for a robot, which have a stall current of 5.5A.(but could probably pull more in very short periods) Preferably, I’d like to use one of those 12V FTC batteries, but the problem is that they cannot handle currents over 20A because of their 20A fuse. The robot will normally draw safely under 20A(the fuse) and 16.5A for the matter(recommended maximum current draw for the motors). How do I prevent the spikes in current, such as when the robot hits a wall, from blowing the fuse?
Not sure if it will help much, but here’s the motor driver I’m planning to use. It has 2 channels, so 2 motors will be wired in parallel on each channel. However, while it states it has overcurrent protection, the datasheet is worded a little weirdly and I’m not sure if it protects against drawing 10A or if its protection is based on its temperature.
clarification: I’m not worried about the driver being able to handle the currents. I’m wondering how I should go about limiting the current draw so it never draws 20A during its peaks; and this is made under the assumption that there is no overcurrent protection on the motor driver.’
currently, this is my list of potential fixes:
capacitors
polyswitch fuses
custom overcurrent circuit(dont want to do, bad at electornics) / different motor driver
