Hi Greetings, I am new to this forum. I recently purchased an SMC 24v12 motor controller, it works wonders once configured. But nothing is perfect and here I have the problem, I am building a robot that works with voice recognition, when acquiring the new controller (I have to purchase two more) I have modified my program and added the SMC class and it works fine, the question comes when I connect several SMCs the code gives an error,
that is, I cannot specify which engine is going to perform one action or another,
I’ll give it to you to see if you can guide me. Thanks.
By the way the code is written in C # for Windows forms application.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.Speech.Recognition;
using System.Speech.Synthesis;
using System.IO;
using ROBOTIS;
using Pololu.UsbWrapper;
using Pololu.SimpleMotorController;
namespace WindowsFormsApp1
public partial class Form1 : Form
SpeechRecognitionEngine reconocedor = new SpeechRecognitionEngine();
SpeechSynthesizer EDU = new SpeechSynthesizer();
bool habilitar_reconocimiento;
string hablar;
public Form1()
InitializeComponent();
Inicio_Gramaticas();
private void Form1_Load(object sender, EventArgs e)
void Inicio_Gramaticas()
reconocedor.LoadGrammarAsync(new Grammar(new GrammarBuilder(new Choices(File.ReadAllLines(@"Comandos\Comandos_Internos.txt")))));
reconocedor.RequestRecognizerUpdate();
reconocedor.SpeechRecognized += Reconocedor_SpeechRecognized;
EDU.SpeakStarted += EDU_SpeakStarted;
EDU.SpeakCompleted += EDU_SpeakCompleted;
reconocedor.AudioLevelUpdated += Reconocedor_AudioLevelUpdated;
reconocedor.SetInputToDefaultAudioDevice();
reconocedor.RecognizeAsync(RecognizeMode.Multiple);
private void Reconocedor_AudioLevelUpdated(object sender, AudioLevelUpdatedEventArgs e)
int nivelaudio = e.AudioLevel;
pb_Audio.Value = nivelaudio;
private void EDU_SpeakCompleted(object sender, SpeakCompletedEventArgs e)
habilitar_reconocimiento = true;
private void EDU_SpeakStarted(object sender, SpeakStartedEventArgs e)
habilitar_reconocimiento = false;
private void Reconocedor_SpeechRecognized(object sender, SpeechRecognizedEventArgs e)
hablar = e.Result.Text;
if (hablar == "Hola")
EDU.SpeakAsync("Hola");
if (hablar == "Adelante")
try
using (Smc device = connectToDevice()) // Find a device and temporarily connect.
device.resume(); // Clear as many errors as possible.
device.setSpeed(3200); // Set the speed to full forward (+100%).
catch (Exception exception) // Handle exceptions by displaying them to the user.
displayException(exception);
if (hablar == "Stop")
try
device.stop(); // Activate the USB kill switch
// Alternatively you can set the speed to 0 to stop the motor,
// but that will only stop the motor if the input mode is Serial/USB:
// device.setSpeed(0);
if (hablar == "Atras")
try
using (Smc device = connectToDevice(39FF - 7406 - 3054 - 3036 - 4923 - 0743)) // Find a device and temporarily connect.
device.setSpeed(-3200); // Set the speed to full reverse (-100%).
Smc connectToDevice()
// Get a list of all connected devices of this type.
List<DeviceListItem> connectedDevices = Smc.getConnectedDevices();
foreach (DeviceListItem dli in connectedDevices)
// If you have multiple devices connected and want to select a particular
// device by serial number, you could simply add a line like this:
if (dli.serialNumber != "39FF-7406-3054-3036-4923-0743")
continue;
Smc device = new Smc(dli); // Connect to the device.
return device; // Return the device.
throw new Exception("Could not find device. Make sure it is plugged in to USB " +
"and check your Device Manager (Windows) or run lsusb (Linux).");
public void displayException(Exception exception)
StringBuilder stringBuilder = new StringBuilder();
do
stringBuilder.Append(exception.Message + " ");
if (exception is Win32Exception)
stringBuilder.Append("Error code 0x" + ((Win32Exception)exception).NativeErrorCode.ToString("x") + ". ");
exception = exception.InnerException;
while (exception != null);
MessageBox.Show(stringBuilder.ToString(), this.Text, MessageBoxButtons.OK, MessageBoxIcon.Error);
