The output I get is the one I posted as a reported for a second machine:
roosemberth@Azulejo-Main-Engine:~$ ssh xu-local
SCP-Svarog@192.168.0.49's password:
Welcome to Ubuntu 12.04.3 LTS (GNU/Linux 3.4.74 armv7l)
* Documentation: https://help.ubuntu.com/
Last login: Fri Dec 27 21:10:17 2013 from 192.168.0.104
SCP-Svarog@odroid-desktop:~$ sudo apt-get install libusb-1.0-0-dev mono-runtime libmono-winforms2.0-cil
[sudo] password for SCP-Svarog:
Reading package lists... Done
Building dependency tree
Reading state information... Done
libusb-1.0-0-dev is already the newest version.
libmono-winforms2.0-cil is already the newest version.
mono-runtime is already the newest version.
The following packages were automatically installed and are no longer required:
uboot-mkimage redboot-tools iw u-boot-tools crda devio uboot-envtools wireless-regdb flash-kernel
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
SCP-Svarog@odroid-desktop:~$ cd maestro_linux/
SCP-Svarog@odroid-desktop:~/maestro_linux$ ls
99-pololu.rules Bytecode.dll FirmwareUpgrade.dll MaestroControlCenter README.txt Sequencer.dll UsbWrapper.dll Usc.dll UscCmd
SCP-Svarog@odroid-desktop:~/maestro_linux$ ./MaestroControlCenter
(process:5504): Gtk-WARNING **: Locale not supported by C library.
Using the fallback 'C' locale.
** (cli:5504): WARNING **: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-gzk9vmccLN: Connection refused
Stacktrace:
at System.Drawing.Font.CreateFont (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x0013f>
at System.Drawing.Font..ctor (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x0007f>
at System.Drawing.Font..ctor (string,single,string) <0x00057>
at (wrapper remoting-invoke-with-check) System.Drawing.Font..ctor (string,single,string) <0xffffffff>
at System.Drawing.SystemFonts.get_DefaultFont () <0x0005b>
at System.Windows.Forms.Theme..ctor () <0x0002b>
at System.Windows.Forms.ThemeWin32Classic..ctor () <0x00013>
at System.Windows.Forms.ThemeVisualStyles..ctor () <0x00013>
at System.Windows.Forms.ThemeEngine..cctor () <0x00063>
at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0xffffffff>
at System.Windows.Forms.X11DesktopColors..cctor () <0x000a7>
at System.Windows.Forms.XplatUIX11..ctor () <0x0014b>
at System.Windows.Forms.XplatUIX11.GetInstance () <0x0004b>
at System.Windows.Forms.XplatUI..cctor () <0x0010b>
at System.Windows.Forms.Application.EnableVisualStyles () <0x0001b>
at Pololu.MaestroControlCenter.Program.Main () <0x0000b>
Native stacktrace:
Debug info from gdb:
Cannot access memory at address 0x616a653c
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0xb52f6460 (LWP 5507)]
[New Thread 0xb6895460 (LWP 5506)]
0xb6f123a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Id Target Id Frame
3 Thread 0xb6895460 (LWP 5506) "cli" 0xb6f14384 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
2 Thread 0xb52f6460 (LWP 5507) "dconf worker" 0xb6e9ebf4 in select () from /lib/arm-linux-gnueabihf/libc.so.6
* 1 Thread 0xb6fd2000 (LWP 5504) "cli" 0xb6f123a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 3 (Thread 0xb6895460 (LWP 5506)):
#0 0xb6f14384 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0xb6f116da in do_futex_wait () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0xb6f11756 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#3 0x001155dc in mono_sem_wait ()
#4 0x000a5b10 in ?? ()
#5 0x000a5b10 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 2 (Thread 0xb52f6460 (LWP 5507)):
#0 0xb6e9ebf4 in select () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0xb6e9ebe8 in select () from /lib/arm-linux-gnueabihf/libc.so.6
#2 0x00000000 in ?? ()
Thread 1 (Thread 0xb6fd2000 (LWP 5504)):
#0 0xb6f123a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0xb6f12394 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0xbe93ade0 in ?? ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted (core dumped)
SCP-Svarog@odroid-desktop:~/maestro_linux$ mono ./MaestroControlCenter
(process:5518): Gtk-WARNING **: Locale not supported by C library.
** (mono:5518): WARNING **: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-gzk9vmccLN: Connection refused
Stacktrace:
Native stacktrace:
[New Thread 0xb5262460 (LWP 5520)]
[New Thread 0xb6800460 (LWP 5519)]
0xb6e7d3a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Id Target Id Frame
3 Thread 0xb6800460 (LWP 5519) "mono" 0xb6e7f384 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
2 Thread 0xb5262460 (LWP 5520) "dconf worker" 0xb6e09bf4 in select () from /lib/arm-linux-gnueabihf/libc.so.6
* 1 Thread 0xb6f3d000 (LWP 5518) "mono" 0xb6e7d3a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 3 (Thread 0xb6800460 (LWP 5519)):
#0 0xb6e7f384 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0xb6e7c6da in do_futex_wait () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0xb6e7c756 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 2 (Thread 0xb5262460 (LWP 5520)):
#0 0xb6e09bf4 in select () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0xb6e09be8 in select () from /lib/arm-linux-gnueabihf/libc.so.6
Thread 1 (Thread 0xb6f3d000 (LWP 5518)):
#0 0xb6e7d3a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0xb6e7d394 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0xbed5bdf0 in ?? ()
SCP-Svarog@odroid-desktop:~/maestro_linux$ sudo ./MaestroControlCenter
(process:5533): Gtk-WARNING **: Locale not supported by C library.
** (cli:5533): WARNING **: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-gzk9vmccLN: Connection refused
Stacktrace:
Native stacktrace:
[New Thread 0xb49ff460 (LWP 5542)]
[New Thread 0xb5305460 (LWP 5536)]
[New Thread 0xb689f460 (LWP 5535)]
0xb6f1c3a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Id Target Id Frame
4 Thread 0xb689f460 (LWP 5535) "cli" 0xb6f1e384 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
3 Thread 0xb5305460 (LWP 5536) "dconf worker" 0xb6e33276 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
2 Thread 0xb49ff460 (LWP 5542) "gdbus" 0xb6e33276 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
* 1 Thread 0xb6fdc000 (LWP 5533) "cli" 0xb6f1c3a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 4 (Thread 0xb689f460 (LWP 5535)):
#0 0xb6f1e384 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0xb6f1b6da in do_futex_wait () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0xb6f1b756 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 3 (Thread 0xb5305460 (LWP 5536)):
#0 0xb6e33276 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0xb6ea4858 in poll () from /lib/arm-linux-gnueabihf/libc.so.6
#2 0xb5eed1e6 in ?? () from /lib/arm-linux-gnueabihf/libglib-2.0.so.0
#3 0xb5eed1e6 in ?? () from /lib/arm-linux-gnueabihf/libglib-2.0.so.0
Thread 2 (Thread 0xb49ff460 (LWP 5542)):
Thread 1 (Thread 0xb6fdc000 (LWP 5533)):
#0 0xb6f1c3a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0xb6f1c394 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0xbec8bf00 in ?? ()
SCP-Svarog@odroid-desktop:~/maestro_linux$ mono --version
Mono JIT compiler version 2.10.8.1 (Debian 2.10.8.1-1ubuntu2.2)
Copyright (C) 2002-2011 Novell, Inc, Xamarin, Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: normal
Notifications: epoll
Architecture: armel,vfp
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: Included Boehm (with typed GC and Parallel Mark)
SCP-Svarog@odroid-desktop:~/maestro_linux$ dpkg --get-selections | grep mono | awk '{print $1}' | xargs dpkg -s | egrep 'Package|Version'
Package: fonts-tlwg-mono
Version: 1:0.4.17-1ubuntu1
Package: libmono-2.0-1
Version: 2.10.8.1-1ubuntu2.2
Package: libmono-2.0-dev
Package: libmono-accessibility2.0-cil
Package: libmono-accessibility4.0-cil
Package: libmono-c5-1.1-cil
Package: libmono-cairo2.0-cil
Package: libmono-cairo4.0-cil
Package: libmono-cecil-private-cil
Package: libmono-cil-dev
Package: libmono-codecontracts4.0-cil
Package: libmono-compilerservices-symbolwriter4.0-cil
Package: libmono-corlib2.0-cil
Package: libmono-corlib4.0-cil
Package: libmono-cscompmgd8.0-cil
Package: libmono-csharp4.0-cil
Package: libmono-custommarshalers4.0-cil
Package: libmono-data-tds2.0-cil
Package: libmono-data-tds4.0-cil
Package: libmono-db2-1.0-cil
Package: libmono-debugger-soft2.0-cil
Package: libmono-debugger-soft4.0-cil
Package: libmono-http4.0-cil
Package: libmono-i18n-cjk4.0-cil
Package: libmono-i18n-mideast4.0-cil
Package: libmono-i18n-other4.0-cil
Package: libmono-i18n-rare4.0-cil
Package: libmono-i18n-west2.0-cil
Package: libmono-i18n-west4.0-cil
Package: libmono-i18n2.0-cil
Package: libmono-i18n4.0-all
Package: libmono-i18n4.0-cil
Package: libmono-ldap2.0-cil
Package: libmono-ldap4.0-cil
Package: libmono-management2.0-cil
Package: libmono-management4.0-cil
Package: libmono-messaging-rabbitmq2.0-cil
Package: libmono-messaging-rabbitmq4.0-cil
Package: libmono-messaging2.0-cil
Package: libmono-messaging4.0-cil
Package: libmono-microsoft-build-engine4.0-cil
Package: libmono-microsoft-build-framework4.0-cil
Package: libmono-microsoft-build-tasks-v4.0-4.0-cil
Package: libmono-microsoft-build-utilities-v4.0-4.0-cil
Package: libmono-microsoft-build2.0-cil
Package: libmono-microsoft-csharp4.0-cil
Package: libmono-microsoft-visualc10.0-cil
Package: libmono-microsoft-web-infrastructure1.0-cil
Package: libmono-microsoft8.0-cil
Package: libmono-npgsql2.0-cil
Package: libmono-npgsql4.0-cil
Package: libmono-opensystem-c4.0-cil
Package: libmono-oracle2.0-cil
Package: libmono-oracle4.0-cil
Package: libmono-peapi2.0-cil
Package: libmono-peapi4.0-cil
Package: libmono-posix2.0-cil
Package: libmono-posix4.0-cil
Package: libmono-profiler
Package: libmono-rabbitmq2.0-cil
Package: libmono-rabbitmq4.0-cil
Package: libmono-relaxng2.0-cil
Package: libmono-relaxng4.0-cil
Package: libmono-security2.0-cil
Package: libmono-security4.0-cil
Package: libmono-sharpzip2.6-cil
Package: libmono-sharpzip2.84-cil
Package: libmono-sharpzip4.84-cil
Package: libmono-simd2.0-cil
Package: libmono-simd4.0-cil
Package: libmono-sqlite2.0-cil
Package: libmono-sqlite4.0-cil
Package: libmono-system-componentmodel-composition4.0-cil
Package: libmono-system-componentmodel-dataannotations4.0-cil
Package: libmono-system-configuration-install4.0-cil
Package: libmono-system-configuration4.0-cil
Package: libmono-system-core4.0-cil
Package: libmono-system-data-datasetextensions4.0-cil
Package: libmono-system-data-linq2.0-cil
Package: libmono-system-data-linq4.0-cil
Package: libmono-system-data-services-client4.0-cil
Package: libmono-system-data-services4.0-cil
Package: libmono-system-data2.0-cil
Package: libmono-system-data4.0-cil
Package: libmono-system-design4.0-cil
Package: libmono-system-drawing-design4.0-cil
Package: libmono-system-drawing4.0-cil
Package: libmono-system-dynamic4.0-cil
Package: libmono-system-enterpriseservices4.0-cil
Package: libmono-system-identitymodel-selectors4.0-cil
Package: libmono-system-identitymodel4.0-cil
Package: libmono-system-ldap2.0-cil
Package: libmono-system-ldap4.0-cil
Package: libmono-system-management4.0-cil
Package: libmono-system-messaging2.0-cil
Package: libmono-system-messaging4.0-cil
Package: libmono-system-net4.0-cil
Package: libmono-system-numerics4.0-cil
Package: libmono-system-runtime-caching4.0-cil
Package: libmono-system-runtime-durableinstancing4.0-cil
Package: libmono-system-runtime-serialization-formatters-soap4.0-cil
Package: libmono-system-runtime-serialization4.0-cil
Package: libmono-system-runtime2.0-cil
Package: libmono-system-runtime4.0-cil
Package: libmono-system-security4.0-cil
Package: libmono-system-servicemodel-discovery4.0-cil
Package: libmono-system-servicemodel-routing4.0-cil
Package: libmono-system-servicemodel-web4.0-cil
Package: libmono-system-servicemodel4.0-cil
Package: libmono-system-serviceprocess4.0-cil
Package: libmono-system-transactions4.0-cil
Package: libmono-system-web-abstractions4.0-cil
Package: libmono-system-web-applicationservices4.0-cil
Package: libmono-system-web-dynamicdata4.0-cil
Package: libmono-system-web-extensions-design4.0-cil
Package: libmono-system-web-extensions4.0-cil
Package: libmono-system-web-mvc1.0-cil
Package: libmono-system-web-mvc2.0-cil
Package: libmono-system-web-routing4.0-cil
Package: libmono-system-web-services4.0-cil
Package: libmono-system-web2.0-cil
Package: libmono-system-web4.0-cil
Package: libmono-system-windows-forms-datavisualization4.0-cil
Package: libmono-system-windows-forms4.0-cil
Package: libmono-system-xaml4.0-cil
Package: libmono-system-xml-linq4.0-cil
Package: libmono-system-xml4.0-cil
Package: libmono-system2.0-cil
Package: libmono-system4.0-cil
Package: libmono-tasklets2.0-cil
Package: libmono-tasklets4.0-cil
Package: libmono-wcf3.0-cil
Package: libmono-web4.0-cil
Package: libmono-webbrowser2.0-cil
Package: libmono-webbrowser4.0-cil
Package: libmono-webmatrix-data4.0-cil
Package: libmono-windowsbase3.0-cil
Package: libmono-windowsbase4.0-cil
Package: libmono-winforms2.0-cil
Package: libmono2.0-cil
Package: mono-2.0-gac
Package: mono-2.0-service
Package: mono-4.0-gac
Package: mono-4.0-service
Package: mono-complete
Package: mono-csharp-shell
Package: mono-devel
Package: mono-dmcs
Package: mono-gac
Package: mono-gmcs
Package: mono-jay
Package: mono-mcs
Package: mono-runtime
Package: mono-runtime-sgen
Package: mono-utils
Package: mono-xbuild
Package: monodoc-base
Package: monodoc-browser
Version: 2.10-2
Package: monodoc-manual
Package: ubuntu-mono
Version: 0.0.40
I was Using the UscCmd code to dig into the Interface, but there’s some stuff as the PWM that remains kind of unknown for me (Questions like is CH 12 the only one PWM-enabled) along with other doubts, I wanted to write the Kernel Module to make it usable for everyone, not only for my project (That’s the gpl and share-alike Idea, Isn’t it?), that’s why I was trying to include all functions for Maestro (even micro-maestro which I don’t have). And as a personal experience for entering into module programming.
Best Regards!
Thank you for your replies!
Merry Chrismas and Happy New Year!
