Hello: I am having this DRV8825 module (#2133) not outputting stepper motor drive signals (A1-A2, B1-B2)… it appears all the inputs are wired correctly:
- I am driving the module with 12VDC, 4A Pwr Adapter. Signal states are as follows:
JP2 - Pin 1 DIR Low
Pin 2 STEP Pulsing - square wave, 1Hz (to 2 Hz)
PIN 3 SLEEP High (INVERTED SIGNAL FROM PIN 8 below)
PIN 4 RESET HIGH (INVERTED SIGNAL FROM PIN 8 below)
PIN 5 M2 HIGH
PIN 6 M1 HIGH
PIN 7 M0 HIGH
PIN 8 ENABLE LOW (INVERTED SIGNAL FROM PIN 3-4 ABOVE)
JP1 PIN 1 VMM 12VDC
PIN 2 GND
PIN 3 B2 RIPPLE ( ~ 0 vdc)
PIN 4 B1 RIPPLE ( ~ 0 vdc)
PIN 5 A1 RIPPLE ( ~ 0 vdc)
PIN 6 A2 RIPPLE ( ~ 0 vdc)
PIN 7 FLT An LED (current limited) is attached to this output
PIN 8 GND GND
- To keep things simple, I have not connected the Stepper motor to the module yet, hoping to see some activity on the output pins first.
- The unit is not getting hot
- The LED on the FAULT line turns ON when RESET / SLEEP are activated (driven low). This is strange, as you would expect Fault to go true when the DRV8825 is active, not when it goes to sleep. The Faul LED turns off when RESET and SLEEP are deactivated.
