Hello
We are using the Pololu High-Power Motor Driver 36v20 CS, to drive a 24V dc motor.
The driver is controlled by PWM, but when the duty cycle goes down over 20% the motor first goes to 0 and then up to the new value.
Example
- Start at 80% duty cycle motor spins at 3000 rpm
- Send 20%
- The motor then goes down to 0 rpm
- And then up to 750 rpm
But if the decrease is under 20%
- Send 60%
- The motor then goes down to 2250 rpm
Is there a workaround this problem so it goes straight to the value?
Simon Hedegaard
