Hello, I am planning to use the pololu dual mc33926 motor driver to control a high current motor.
The motor has a stall current of 2.5A so it is within the recommended limits, however it should run for quite long periods of
time doing cycles (go forward,stop,go backwards,stop), so I am afraid that the driver may end up heating too much, negatively
affecting the performance.
I would like to know if it is possible to use both of the connections (and drivers) in parallel to drive a single motor , this way
the current would be shared by the two ICs, and it may work better over long periods of time.
I know this is possible with other kinds of dual H bridges like the l298, but since that driver integrates all in one single IC and
this one uses two independents ICs; I am not quite sure it would work.
Does anyone have any experience using the driver this way?
Thanks in advance.
