analog input using potentiometer or joystick to pololu a-star, advanced packet serial out to RoboClaw with encoder feedback for position control hooked up exactly like on page 48 in the manual. pot wiper or center connection is wired to pin A0. on the a-star
I have been trying to teach myself the arduino language. I can get individual parts working, but I cant seem to get all the parts talking to each other. I was having some hard ware issues I think I have them figured out. still having problems with the sketches.
an example is.
[code]
//Position PID example. Velocity PID is not used. Speeds are not controlled by feedback.
//This example is the most like a standard RC servo
//Warning!!!
//Arduino Mega and Leonardo chips only support some pins for receiving data back from the RoboClaw
//This is because only some pins of these boards support PCINT interrupts or are UART receivers.
//Mega: 0,10,11,12,13,14,15,17,19,50,51,52,53,A6,A7,A8,A9,A10,A11,A12,A13,A14,A15
//Leonardo: 0,8,9,10,11
//Arduino Due currently does not support software serial. Only hardware uarts can be used, pins 0/1, 14/15, 16/17 or 18/19.
//Includes required to use Roboclaw library
#include “BMSerial.h”
#include “RoboClaw.h”
//Roboclaw Address
#define address 0x80
//Note: PID coeffcients will need to be tuned for this code to work with your motor.
//Velocity PID coefficients
#define Kp 0
#define Ki 0
#define Kd 0
#define Qpps 3600
//Position PID coefficients
#define PosKp 20000
#define PosKi 0
#define PosKd 100000
#define KiMax 0
#define DeadZone 0
#define Min -1500
#define Max 1500
//Definte terminal for display. Use hardware serial pins 0 and 1
BMSerial terminal(0,1);
//Setup communcaitions with roboclaw. Use pins 10 and 11 with 10ms timeout
RoboClaw roboclaw(10,11,10000);
//Display Encoder and Speed for Motor 1
void displayspeed(void)
uint8_t status1,status2;
bool valid1,valid2;
int32_t enc1 = roboclaw.ReadEncM1(address, &status1, &valid1);
int32_t speed1 = roboclaw.ReadSpeedM1(address, &status2, &valid2);
if(valid1){
terminal.print(“Encoder1:”);
terminal.print(enc1,DEC);
terminal.print(" “);
terminal.print(status1,HEX);
terminal.print(” “);
if(valid2){
terminal.print(“Speed1:”);
terminal.print(speed1,DEC);
terminal.print(” ");
terminal.println();
//This function will delay the program so the loop it
//executes in will run no more than every val milliseconds
int lasttime=0;
void rate(int val)
while(millis()-lasttime<val);
lasttime = millis();
void SetPosition(int pos)
//Send position command. The Roboclaw library is using acknowledgement
//When a valid command is received the roboclaw sends back a byte to ackowledge it.
if(!roboclaw.SpeedAccelDeccelPositionM1(address,0,3600,0,pos,1))
terminal.println(“SpeedAccelDeccelPositionM1 Failed!”);
displayspeed();
//This is the first function arduino runs on reset/power up
void setup() {
//Open terminal and roboclaw serial ports
terminal.begin(57600);
roboclaw.begin(38400);
terminal.println(“Starting…”);
//Use Encoder and Enable encoders in RC mode
//roboclaw.SetM1EncoderMode(address,0x81);
//Set PID Coefficients
roboclaw.SetM1VelocityPID(address,Kd,Kp,Ki,Qpps);
roboclaw.SetM1PositionPID(address,PosKd,PosKp,PosKi,KiMax,DeadZone,Min,Max);
//Save settings in Roboclaw eeprom. Uncomment to save settings.
//roboclaw.WriteNVM(address);
//Main loop
void loop() {
for(int pos = -1500;pos<1500;pos+=55){
rate(10);
SetPosition(pos);
for(int pos = 1500;pos>-1500;pos-=55){
rate(10);
SetPosition(pos);
}[/code]
when I try to adapt this to my needs I get errors like(SpeedAccelDeccelPositionM1 Failed!)
tried using others sketchs but none of them are suted for what I am doing.
please send me in the right direction…
