Hi, does DualVNH5019MotorShield’example sketch use pwm frequencies to control dc motors?
Our Arduino library for the Pololu Dual VNH5019 Motor Driver Shield uses 20 kHz hardware PWM if you are using a board based on the ATmega168, ATmega328P, ATmega328PB, or ATmega32U4. On other boards, it uses Arduino’s analogWrite() function, which typically uses a frequency of 490 Hz. However, please note that the speed of the motor is controlled by the duty cycle of the PWM signal (not the frequency).
